Product
Lexar JumpDrive V20 Flash Drive 8GB USB 2.0 (3 Assorted Colours)
Quicklinx: C7PJWS00 Mfr#: LJDV20-8GBABEUW3
Easily organize or archive your important files with the Lexar JumpDrive V20 USB multipack. So whether you are storing vacation photos, holiday memories, taxes, or other important documents, you can see what is on each drive at a glance.
  • Easily organize or archive files
    Forget where you stored your photos from last year's trip? Wondering how to best archive all your tax files? Need a handy way to file class projects and assignments? The Lexar JumpDrive V20 USB multipack makes quick work of getting your files in order.
  • Designed for convenience
    The JumpDrive V20 USB multipack include 8 GB drive that sport a slim design and provide reliable simple storage for life on the go. Compatible with both PC and Mac systems, the drive allows you to quickly and easily store a large number of photos, files, songs, and videos. Each drive also sports an LED activity light that blinks during data transfer, so you know when the job is done.
  • Lexar performance, quality, compatibility, and reliability
    This USB flash drive product designs undergo extensive testing in the Lexar quality labs, facilities with more than 1100 digital devices, to ensure performance, quality, compatibility, and reliability.
Lexar JumpDrive V20 - USB flash drive - 8 GB
USB flash drive
Packaged Quantity
3 (specifications are for single item)
Interface Type
USB 2.0
Storage Capacity
8 GB
Enclosure Colour
Assorted
2 years warranty
Packaged Quantity
USB flash drive
Storage Capacity
8 GB
Enclosure Colour
Assorted
Compatibility
Non-specific
Interface Type
USB 2.0
LED access indicator
Labels
