Product
Lexar JumpDrive TwistTurn - USB flash drive - 64 GB - USB 2.0 - black
Quicklinx: 753RWS00 Mfr#: LJDTT64GASBEU
Lexar JumpDrive TwistTurn is a high-capacity USB flash drive that provides a convenient solution for storing, transferring, and sharing multimedia and more.
JumpDrive TwistTurn has a simple plug-and-play design that allows you to quickly and easily store files, so wherever you go, your information goes with you. Its durable hinged jacket rotates to easily access a USB port, and it sports an LED activity light that blinks during file transfer, so you know when the job is done. JumpDrive TwistTurn also works across platforms, giving you flexibility and ease of use.
  • High-capacity storage and stylish housing
    The drive has a capless design with a rotating case to protect the drive and its contents, providing an excellent combination of durability and convenience.
  • Plug-and-play design with great features
USB flash drive
Interface Type
USB 2.0
Storage Capacity
64 GB
Enclosure Colour
Microsoft Certification
Compatible with Windows 7
2 years warranty
USB flash drive
Storage Capacity
64 GB
Enclosure Colour
Compatibility
Non-specific
Interface Type
USB 2.0
LED access indicator
Plug and Play
