Easily expand the storage capabilities of your devices with the low-profile, plug-and-stay Lexar JumpDrive S45 USB 3.0 flash drive. Quickly and securely store and transfer photos, videos, and files at USB 3.0 speeds - up to 150 MB/s read and 45 MB/s write.
Easily expand the storage capabilities of your laptop, TV, or car stereo system with JumpDrive S45. Its compact, low-profile design means you can plug it in and forget it - it's always at the ready for storing and accessing files.
Plug-and-stay storage for your favorite devices
Easily expand the storage capabilities of your laptop, TV, or car stereo system with JumpDrive S45. Its compact, low-profile design means you can plug it in and forget it - it's always at the ready for storing and accessing files. -
Store and transfer content at USB 3.0 speeds
Who wants to spend extra time waiting for files to transfer? JumpDrive S45 provides speeds up to 150 MB/s read and 45 MB/s write. Quickly transfer a 3GB HD video clip in less than 90 seconds, compared to more than 4 minutes using a standard USB 2.0 drive. And for added versatility, the drive is backwards compatible with USB 2.0 devices. -
Securely protect your files
JumpDrive S45 includes EncryptStick Lite software, an advanced security solution with 256-bit AES encryption to help protect your essential files against corruption, loss, and deletion. Easily create a password-protected vault that automatically encrypts data. And for peace of mind, files that are deleted from the vault are securely erased and can't be recovered.
- Lexar JumpDrive S45 - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 32 GB
- Encryption Algorithm
- 256-bit AES
- Enclosure Colour
- Blue
- Software Included
- EncryptStick Lite
- 3-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- 256-bit AES
- Enclosure Colour
- Blue
- Read Rate
- Up to 150 MB/s
- Write Rate
- Up to 30 MB/s
- Interface Type
- USB 3.0
- Key ring loop
- Software Included
- EncryptStick Lite
- Limited warranty - 3 years
