Lexar JumpDrive C20i 32GB
Quicklinx: C5V7WS00 Mfr#: LJDC20I-32GBBEU
With today's overflow of content - created, captured, and consumed - it's easy to run out of space on your iPhone or iPad. Now you don't need to delete your favorite photos and videos to make room for more. The multitasking Lexar JumpDrive C20i flash drive makes it easy to offload, add, or back up files, as well as charge your iOS devices on the go. No battery needed and no network required.
  • Easily expand the memory of your iPhone or iPad
  • Convenient cable design
    Multitasking goes upscale with the sleek metal finishings of JumpDrive C20i. The Lightning connector fits with most iOS cases, and with its ability to offload, back up, and charge your iOS devices, it's a true workhorse for road warriors or anyone on the go.
  • Automatically and securely sync your photos and video
    JumpDrive C20i works with use of a free file management. The app also allows you to back up files when connected. You can offload lots of content from your devices to create room for even more.
  • Lexar performance, quality, compatibility, and reliability
    All Lexar memory card, card reader, and USB flash drive product designs undergo extensive testing in the Lexar Quality Labs, facilities with more digital devices, to ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
Lexar JumpDrive C20i - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.0 / Apple Lightning
Storage Capacity
32 GB
Apple MacOS X or later, Apple iOS 7, Apple iOS 8, Microsoft Windows 7 / 8 / 10
3-year warranty
USB flash drive
Storage Capacity
32 GB
Read Rate
Up to 95 MB/s
Write Rate
Up to 20 MB/s
Interface Type
Metallic finish
Limited warranty - 3 years
