Whether you're a professional photographer, videographer, or adventure photography enthusiast, the Lexar Professional 2933x XQD 2.0 card provides performance you can trust. This rugged, high-speed card supports both PCI Express Gen 2 and USB 3.0 interfaces, and provides high-speed performance, durability, and reliability, with a read transfer speed up to 2933x (440 MB/s).
Shoot stunning, high-quality images and 4K video
Designed to leverage the capabilities of the latest generation of high-definition camcorders and high-resolution DSLR cameras, the Lexar Professional 2933x XQD 2.0 card allows you to capture stunning, high-quality images and extended lengths of 4K video. -
Capture adventure with ultimate durability
Whether you're chasing sunsets or road races - or any other adventure, the Lexar Professional 2933x XQD 2.0 card delivers the rugged durability you need to get that perfect shot. It provides exceptional resilience in regards to water, temperature, shock/vibration, and more. So from the Sahara to Siberia, you have the peace of mind that you've got a card you can trust to capture breathtaking images. -
Save time with dramatically accelerated workflow
The high-speed performance of the card allows you to quickly shoot and transfer your files. And when used with an XQD 2.0 USB 3.0 reader, such as the Lexar Professional Workflow XR2, you'll maximize the read transfer speed capability of the card. This dramatically accelerates your workflow from start to finish, so you can save time and get back to the business of photography.
- Lexar Professional - flash memory card - 64 GB - XQD 2.0
- Product Type
- Flash memory card
- Form Factor
- XQD 2.0 Memory Card
- Storage Capacity
- 64 GB
- Speed Rating
- 2933x
- Software Included
- Image Rescue software
- Limited lifetime warranty (Germany - 10 years)
- Product Type
- Flash memory card
- Storage Capacity
- 64 GB
- Speed Rating
- 2933x
- Read Rate
- Up to 440 MB/s
- Write Rate
- Up to 400 MB/s
- Form Factor
- Shockproof, water resistant, vibration-proof, temperature-proof
- Software Included
- Limited warranty - lifetime , Germany: limited warranty - 10 years
