Quickly and securely transfer photos, videos, and files with the affordable, high-performance Lexar JumpDrive S75 USB 3.0 drive. It features a retractable connector with an easy-to-use thumb slide.
Store and transfer content faster
With a busy life on the go and so much to do, the last thing you want is to spend extra time waiting for your files to transfer. The drive delivers high read and write speeds. And for added versatility, the drive is backwards compatible with USB 2.0 devices. -
Designed for convenience
Beyond its performance and good looks, JumpDrive S75 is designed for convenience. It sports a retractable connector with easy-to-use thumb slide. -
Lexar performance, quality, compatibility, and reliability
All Lexar memory card, card reader, storage drive, and USB flash drive products ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
- Lexar JumpDrive S75 - USB flash drive - 64 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 64 GB
- Encryption Algorithm
- 256-bit AES
- Enclosure Colour
- Green
- Software Included
- EncryptStick Lite
- 3-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 64 GB
- 256-bit AES
- Enclosure Colour
- Green
- Read Rate
- Up to 150 MB/s
- Write Rate
- Up to 60 MB/s
- Interface Type
- USB 3.0
- Retractable connector
- Software Included
- EncryptStick Lite
- Limited warranty - 3 years
