Product
Brand
Lexar 4GB MicroSDHC High Speed Card with Full Size SD Adapter
Quicklinx: C7S6WS00 Mfr#: LSDMI4GBABEUA
The high-capacity Lexar microSDHC memory card is ideal for increasing the storage capacity of your SDHC-enabled cell phone, PDA, or other mobile device, allowing you to download, play, and store media and applications.
In the ever-changing world of mobile technology, you need a memory card that can keep up with the demands of the latest applications found in today's feature-rich devices. The Lexar microSDHC card is designed to maximize the capacity and capabilities of your microSDHC-enabled handheld device. It can significantly increase your storage capacity for multimedia files, including songs, photos, video, games, ringtones, and more.
Lexar - flash memory card - 4 GB - microSDHC
Flash memory card
microSDHC
Storage Capacity
4 GB
Speed Rating
Class 2
Included Memory Adapter
microSD to SD adapter
Flash memory card
Storage Capacity
4 GB
Compatibility
Non-specific
SD Speed Class
Class 2
microSDHC
15 mm
11 mm
Thickness
1 mm
