Faster File Transfer with USB 3.0 Technology
Quickly and securely transfer photos, videos, and files with the affordable, high-performance Lexar JumpDrive S35 USB 3.0 drive. It features a stylish swivel design with a retractable connector.
Convenient, Reliable Portable Storage
Store and Transfer Content Faster. With a busy life on the go and so much to do, the last thing you want is to spend extra time waiting for your files to transfer. With speeds up to 150MB/s read and 60MB/s write, you can now transfer a 3GB HD video clip in less than 1 minute, compared to the 4 minutes it takes using a standard USB 2.0 drive. And for added versatility, the drive is backwards compatible with USB 2.0 devices.
Securely protect and delete files on the go. Looking to protect personal information, financial records, or other sensitive files on the go? JumpDrive S35 includes EncryptStick™ Lite software, an advanced security solution with 256-bit AES encryption to help protect your essential files against corruption, loss, and deletion. Easily create a password-protected vault that automatically encrypts data. And for peace of mind, files that are deleted from the vault are securely erased and can’t be recovered.
Designed for Convenience. Beyond its performance and good looks, JumpDrive S35 is designed for convenience. Its small slim, swivel design includes an automatically retractable connector, which means there’s no cap to lose. And with the included key ring loop, you can easily attach it to your keychain, computer bag, backpack, or purse.
Lexar Performance, Quality, Compatibility, and Reliability. All Lexar memory card, card reader, storage drive, and USB flash drive product designs undergo extensive testing in the Lexar Quality Labs, facilities with more than 1,100 digital devices, to ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
For more than 15 years, Lexar has been trusted as a leading global brand of memory solutions. Our award-winning lineup includes memory cards, USB flash drives, readers, and storage drives. With so many options, it’s easy to find the right Lexar solution to fit your needs.
- Lexar JumpDrive S35 - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 32 GB
- Encryption Algorithm
- 256-bit AES
- Enclosure Colour
- Green
- Software Included
- EncryptStick Lite
- 3 years warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- 256-bit AES
- Enclosure Colour
- Green
- Compatibility
- Non-specific
- Read Rate
- Up to 150 MB/s
- Write Rate
- Up to 60 MB/s
- Interface Type
- USB 3.0
- Retractable connector, swivel cap, key ring loop
- Software Included
- EncryptStick Lite
- Limited warranty - 3 years
