Your basket is empty
Lexar 32GB JumpDrive M20
Quicklinx: BCFDWS00 Mfr#: LJDM20-32GBBEU
Capacity: 32GB
Interface: USB 3.0
29 in stock
£10.40 ex VAT
£12.48 inc VAT
Standard delivery Delivered within 3-5 working days
Quickly and easily transfer and share photos, music, videos, and files between your Android tablet, smartphone, or computer with the Lexar JumpDrive M20 Mobile USB 3.0 flash drive.
No more searching for hotspots, draining your data plan, or toting clumsy cables with you on the go. The Lexar JumpDrive M20 Mobile USB 3.0 flash drive lets you move files between your On-The-Go (OTG)-enabled Android devices, or from device to computer - no data connection or power required.
The drive leverages USB 3.0 performance with up to 120 MB/s read transfer speeds. You can quickly transfer a 3 GB HD video clip in less than one minute - compared to the 4 minutes it takes using a standard USB 2.0 drive. And for added versatility, the drive is also backwards compatible with USB 2.0 devices.
Lexar JumpDrive M20 Mobile - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
3 years warranty
USB flash drive
Storage Capacity
32 GB
Compatibility
Non-specific
Read Rate
Up to 120 MB/s
Write Rate
Up to 55 MB/s
Interface Type
USB 3.0
Retractable connector, micro-USB connector
Limited warranty - 3 years
Capacity: 32GB
Interface: USB 3.0
Brand: Lexar
Price Range Ex VAT: 0 - 50
