Designed for use with advanced devices with USB Type-C connectors, the Lexar JumpDrive M20C USB Type-C flash drive provides a seamless way to move transfer and share content between your Type-C enabled smartphone, tablet, and computer. This high-performance 2-in-1 solution makes quick work of transferring files on the go.
Manage your content on the go
With overflow of content - created, captured, and consumed - it's easy to run out of space on your smartphone or tablet. Now you don't need to delete your favorite photos and videos to make room for more. -
No matter which way is up
No more fumbling to put your USB flash drive in the right way. The USB Type-C connector has a reversible design, so no matter which way you use it, it's the right way. -
Move files at USB 3.0 speeds
Powered by USB 3.0 performance, JumpDrive M20C makes quick work of offloading files. With super high read speeds, you can transfer a high-definition video clip in a fraction of time. And for added versatility, the drive is backwards compatible with USB 2.0 devices. -
Convenient portability with a protective cap design
JumpDrive M20C sports a clear end cap with key ring loop, making it easy to attach to a bag or keychain and go. -
Expand the memory of your USB Type-C mobile devices
With its ample capacity, the JumpDrive M20C also lets you offload lots of content from your tablet or smartphone to create more room, and also provides a great way to back up files.
- Lexar JumpDrive M20c - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0 / USB-C
- Storage Capacity
- 32 GB
- 3-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- Read Rate
- Up to 150 MB/s
- Write Rate
- Up to 60 MB/s
- Interface Type
- USB 3.0 / USB-C
- Retractable connector, USB On-The-Go compatible, key ring loop
- Limited warranty - 3 years
