Lexar JumpDrive TwistTurn is a high-capacity USB flash drive that provides a convenient solution for storing, transferring, and sharing multimedia and more.
JumpDrive TwistTurn has a simple plug-and-play design that allows you to quickly and easily store files, so wherever you go, your information goes with you. Its durable hinged jacket rotates to easily access a USB port, and it sports an LED activity light that blinks during file transfer, so you know when the job is done. JumpDrive TwistTurn also works across platforms, giving you flexibility and ease of use.
High-capacity storage and stylish housing
The drive has a capless design with a rotating case to protect the drive and its contents, providing an excellent combination of durability and convenience. -
Plug-and-play design with great features
- Lexar JumpDrive TwistTurn - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 16 GB
- Enclosure Colour
- Silver
- Microsoft Certification
- Works with Windows Vista
- 2-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- Enclosure Colour
- Silver
- Interface Type
- USB 2.0
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Limited warranty - 2 years
