The Lexar JumpDrive S70 USB flash drive provides convenient, reliable portable storage for life on the go. This Hi-Speed USB drive with retractable connector and convenient thumb slide provides an excellent solution for storing, transferring, and sharing your valuable files, photos, videos, and more.
Plug and Play design with great features
The JumpDrive S70 USB flash drive has a simple Plug and Play design that allows you quickly and easily store files, so wherever you go, your information goes with you. The drive also sports an LED activity light that blinks during data transfer, so you know when the job is done and data loss is averted. -
Lexar performance, quality, compatibility, and reliability
All Lexar memory cards, card reader, and USB flash drives product designs undergo extensive testing in the Lexar Quality Labs, facilities with more than 1100 digital devices, to ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
- Lexar JumpDrive S70 - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 16 GB
- Enclosure Colour
- Grey
- 2-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- Enclosure Colour
- Grey
- Interface Type
- USB 2.0
- Retractable connector, LED access indicator
- Plug and Play, FCC Part 15, RoHS
- Limited warranty - 2 years
