Quickly and easily transfer and share photos, music, videos, and files between your Android tablet, smartphone, or computer with the Lexar JumpDrive M20 Mobile USB 3.0 flash drive.
No more searching for hotspots, draining your data plan, or toting clumsy cables with you on the go. The Lexar JumpDrive M20 Mobile USB 3.0 flash drive lets you move files between your On-The-Go (OTG)-enabled Android devices, or from device to computer - no data connection or power required.
The drive leverages USB 3.0 performance with up to 120 MB/s read transfer speeds. You can quickly transfer a 3 GB HD video clip in less than one minute - compared to the 4 minutes it takes using a standard USB 2.0 drive. And for added versatility, the drive is also backwards compatible with USB 2.0 devices.
Easily transfer files between devices
Quickly and easily transfer and share photos, music, videos, and files between your Android tablet, smartphone, or computer with the Lexar JumpDrive M20 Mobile USB 3.0 flash drive. -
Transfer and share files between your Android tablet and smartphone without cables or Wi-Fi
No more searching for hotspots, draining your data plan, or toting clumsy cables with you on the go. The Lexar JumpDrive M20 Mobile USB 3.0 flash drive lets you move files between your On-The-Go (OTG)-enabled Android devices, or from device to computer - no data connection or power required. -
Store and share content faster
The drive leverages USB 3.0 performance with up to 120 MB/s read transfer speeds. You can quickly transfer a 3 GB HD video clip in less than one minute - compared to the 4 minutes it takes using a standard USB 2.0 drive. And for added versatility, the drive is also backwards compatible with USB 2.0 devices. -
Increase storage and back up files
With capacity of 16 GB, the drive also lets you offload lots of content from your tablet or smartphone to create more room, and also provides a great way to back up files. You can also download a file management App like ASTRO File Manager from the Google Play store to quickly and easily manage files from the cloud and mobile devices. -
Enjoy easy connectivity
Faster and more convenient than using Wi-Fi or data connectivity, the USB On-The-Go capabilities of the high-performance Lexar JumpDrive M20 Mobile allow you to easily transfer, store, and swap files between your tablet and smartphone for ultimate convenience, wherever you may be. -
Convenient portability with retractable design
This 2-in-1 drive sports a thumb slide design, with a connector on each end - micro-USB and USB 3.0 - that both retract. This makes it easy to carry and means there are no caps to lose. -
Lexar performance, quality, compatibility, and reliability
All Lexar memory card, card reader, and USB flash drive product designs undergo extensive testing in the Lexar quality labs, facilities with more than 1,100 digital devices, to ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
- Lexar JumpDrive M20 Mobile - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 16 GB
- 3-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- Read Rate
- Up to 120 MB/s
- Write Rate
- Up to 20 MB/s
- Interface Type
- USB 3.0
- Retractable connector, micro-USB connector
- Limited warranty - 3 years
