Lexar 128GB JumpDrive S75 USB 3.0
Quicklinx: BCG1WS00 Mfr#: LJDS75-128ABEU
Quickly and securely transfer photos, videos, and files with the affordable, high-performance Lexar JumpDrive S75 USB 3.0 drive. It features a retractable connector with an easy-to-use thumb slide.
  • Store and transfer content faster
    With a busy life on the go and so much to do, the last thing you want is to spend extra time waiting for your files to transfer. The drive delivers a very high writing speed.
  • Designed for convenience
    Beyond its performance and good looks, JumpDrive S75 is designed for convenience. It sports a retractable connector with easy-to-use thumb slide.
  • Colorful style
    Lexar JumpDrive S75 suits your needs and reflects your personality. It also provides you with a built-in color coding system to help you organize your drives and their contents.
  • Lexar performance, quality, compatibility, and reliability
    All Lexar USB flash drives ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
Lexar JumpDrive S75 - USB flash drive - 128 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
128 GB
Encryption Algorithm
256-bit AES
Enclosure Colour
Software Included
EncryptStick Lite
3-year warranty
USB flash drive
Storage Capacity
128 GB
256-bit AES
Enclosure Colour
Read Rate
Up to 150 MB/s
Write Rate
Up to 60 MB/s
Interface Type
USB 3.0
Retractable connector
Software Included
EncryptStick Lite
Limited warranty - 3 years
