Your basket is empty
Levelone 10/100/1000BASE-T to 1000BASE-X SFP Converter
Quicklinx: BZ5SWS00 Mfr#: GVT-2000
The GVT-2000 media converter is able to convert network signals between copper and fiber-optic based networks. The converter provides a SFP slot for 1000Base-X Gigabit optic module and a 10/100/1000Base-T RJ-45 port, supports full duplex and half duplex switch connectivity and 10Base-T, 100Base-TX and 1000Base-T auto-sensing.
The device features built-in Dip switches for easy converter configuration, which function on the Smart LFP (Link Fault Pass-through), allowing the converter to monitor both the fiber and copper ports for signal loss, as well as cut through and smart pass through mode.
The GVT-2000 is able to operate in temperatures from -10° up to 55° Celsius. The converter can be used as a standalone unit or as a slide-in module to the CHV-2000 19" converter rack, which can accommodate up to 14 units for use in a central wiring closet.
LevelOne GVT-2000 - fibre media converter - 10Mb LAN, 100Mb LAN, GigE
Fibre media converter - RJ-45 / SFP (mini-GBIC)
External
Cabling Type
10Base-T, 100Base-TX, 1000Base-T, 1000Base-X
Data Transfer Rate
1 Gbps
7.1 cm x 9.4 cm x 2.6 cm
420 g
External
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Power, link/activity
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, Link Fault Pass Through function (LFP), Jumbo Frames support, built-in DIP switch
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3x
1 x Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-X - SFP
FCC
External power adapter
7.1 cm
9.4 cm
2.6 cm
420 g
-10 °C
55 °C
5 - 90% (non-condensing)
