Lenovo Yoga Pro 3 1 Atom X5-Z8500 2GB 32GB 10" Touch Andriod OS - B
Quicklinx: C9NNWS00 Mfr#: ZA0F0047GB
The ultimate entertainment tablet – with a brilliant QHD screen to binge-watch your favourite TV programmes and a rotating projector plus powerful speakers to share the fun with anyone.
  • Integrated rotatable projector
    The Yoga Tab 3 Pro boasts a revolutionary integrated projector that turns any room into your very own theater. Experience a new way to enjoy videos and movies. Use the rotatable hinge and super bright 50 lumen output to project an image of up to 70" (178cm) on any wall or ceiling.
  • Dazzling visuals
    The YogaTab 3 Pro's QHD display is perfect for immersive gaming and rich, detailed video. It also delivers crisp, bright visuals for a great viewing experience under all angles and ambient lights.
  • Immersive audio
    The Yoga Tab 3 Pro delivers rich theater sound that you will not experience on any other tablet. The four big integrated front-facing JBL speakers and powerfully immersive Dolby Atmos sound provide loud, clear, and dynamic audio– even without headphones!
  • Epic battery life
    The Yoga Tab 3 Pro keeps going and going with its outstanding battery life. With up to 18 hours on one charge, it's enough to watch two seasons of your favorite TV show back to back. In fact the battery is so powerful, it also comes with a USB'On the Go' powerbank, allowing you to charge all your other devices. Battery life is an estimated maximum. Actual battery life may vary based on many factors.
  • Four ways to use your tablet
    Scroll through recipes while you cook, check your social feeds while you eat, and watch movies while you work out. Yoga Tablet 3 Pro's innovative design places a battery cylinder and kickstand on the side of the device, shifting the center of gravity and opening up multiple ways to use it: Hold, Tilt, Stand, and Hang.
  • Stylish and safe
    YogaTab 3 Pro looks great with its comfortable faux-leather finish and durable metal chassis components. But its durability isn't limited to the quality of its materials– Yoga Tab 3 Pro also has splashproof IP21 certification. No need to be afraid of the water!
  • AnyPen technology
    Lenovo AnyPen technology detects any conductive object as a pen. That's useful when you're using your tablet to take notes, sketch, keeping your dirty hands away from the screen!
  • Great connectivity
    The Yoga Tab 3 Pro supports dual band WiFi for stable connections over larger distances.
Lenovo Yoga Tablet 3 Pro ZA0F - tablet - Android 5.1 - 32 GB - 10.1"
Tablet
Operating System
Android 5.1
Display
10.1" IPS - 2560 x 1600 (299 ppi) - Multi-Touch
Intel Atom x5 Z8500 (Quad-Core) - 64-bit
Processor Clock Speed
2.24 GHz
Storage
32 GB eMMC
RAM
2 GB
Supported Flash Memory Cards
microSD
Wireless Connectivity
802.11a/b/g/n, Bluetooth 4.0
Rear Camera
13 Megapixel
Front Camera
5 Megapixel
Navigation System
GPS/GLONASS
Battery Run Time
Up to 18 hours
17.9 cm x 0.468 cm x 24.7 cm
665 g
English / Germany
Manufacturer Selling Program
TopSeller
1-year warranty
Tablet
Operating System
Android 5.1
Display
10.1" IPS
Resolution
Colour Gamut
70%
Touchscreen
Multi-Touch
Image Aspect Ratio
16:10
10-point multi-touch
Intel Atom x5 Z8500
2.24 GHz
Number of Cores
Quad-Core
64-bit Computing
Storage
32 GB eMMC
RAM
2 GB - LPDDR3 SDRAM
microSD
Max Supported Capacity
128 GB
Communications
Rear Camera
Sensor Resolution
13 Megapixel
Front Camera
Sensor Resolution
5 Megapixel
Navigation System
Receiver
GPS/GLONASS
Multimedia
Supported Digital Audio Standards
Dolby Atmos
Audio
Four speakers
Expansion and Connectivity
1 x Micro-USB , 1 x headset mini jack (3.5mm)
10200 mAh
Run Time
Up to 18 hours
Standby Time
1176 h
Case Material
Plastic, metal
Sensors
Ambient light sensor, digital compass, G-sensor
Built-in projector
Vibrating Alert
Power adapter
Micro-USB cable
English / Germany
TopSeller
17.9 cm
0.468 cm
24.7 cm
665 g
Limited warranty - 1 year - pick-up and return
