Lenovo YOGA 900-13ISK2 i7-6560U 8GB 256GB SSD 13.3" Touch Win 10 Ho
Quicklinx: C9N1WS00 Mfr#: 80UE0018UK
  • Core i7
  • Bluetooth 4.0
  • IEEE 802.11n
Life moves fast and so do you. Do more, faster with the latest Intel Core processors and customize your Windows 10 experience to make it yours. Drown out distractions with JBL speakers that deliver rich stereo sound and premium Dolby Home Theater for an immersive audio experience Starting at a mere 2.8 lbs and just 0.59" thick, the Yoga 900 is ultraportable - it's perfect for doers on the go, and is the world's thinnest Intel Core convertible. Bend it, flip it, or fold it to experience your apps in a way you never have before. The QHD+ display with In-Plane Switching (IPS) technology allows for vivid colors and looks great from any angle. Into marathons? Enjoy movies or TV shows from your favorite streaming service. Working from home? Take productivity to the next level with an improved keyboard and dedicated function row and enjoy web conferences or online video chats like you're really there with the integrated webcam
  • Power user
  • On the go
  • Work or play
    The QHD+ display with In-Plane Switching (IPS) technology allows for vivid colors and looks great from any angle. Into marathons? Enjoy movies or TV shows from your favorite streaming service. Working from home? Take productivity to the next level with an improved keyboard and dedicated function row and enjoy web conferences or online video chats like you're really there with the integrated webcam.
  • Cool factor
    It's in the details. They are-engineered the fan to allow the Yoga 900 to stay thin and cool. Specially designed vents in the hinge allow for excellent cooling, dust-resistance, and a clean design that's quiet. And it's beautiful. The elegant hinge is composed of 813 individual components for fluid transitions between modes. Auto Lock hinge technology allows you to easily open and close the laptop, even with one hand.
Lenovo Yoga 900-13ISK2 - 13.3" - Intel Core i7 - 6560U - 8 GB RAM - 256 GB SSD - UK
Ultrabook - flip design
Operating System
Win 10 Home 64-bit
Intel Core i7 (6th Gen) - 6560U / 2.2 GHz, up to 3.2 GHz / 4 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Display
13.3" LED backlight touchscreen 3200 x 1800 / QHD+
Graphics
Intel Iris Graphics 540
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
4-cell - up to 9 hours
Ambient light sensor, G-sensor
Silver
32.4 cm x 22.5 cm x 1.49 cm
1.29 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 1 year - pick-up and return
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6560U / 2.2 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Integrated memory controller
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
256 GB SSD M.2
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
3200 x 1800 (QHD+)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
One Glass Solution
Audio & Video
Graphics Processor
Camera
Yes - 720p
Resolution
1 Megapixel
Sound
Stereo speakers, two microphones
High Definition Audio, Dolby Audio Premium
Audio Features
Output: JBL
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260 - M.2 Card
4-cell lithium polymer
66 Wh
Run Time
Up to 9 hours
AC Adapter
Input
Output
65 Watt, 20 V, 3.25 A
Connections & Expansion
Interfaces Details
2 x USB 3.0 , USB 2.0 (charging) , Headphone/microphone combo jack , USB-C
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Silver
Case Material
Aluminum, magnesium-aluminum alloy
Integrated Options
Administrator password, hard drive password, power-on password, digital compass, lock display rotation function, Windows button
Power adapter
RoHS
Localization
1.29 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
