Form meets function with the 14" Yoga 710. An innovative antenna hinge provides stronger, more stable Wi-Fi, while state-of-the-art processing and graphics deliver breathtaking performance, one of the fastest around. What's more, the edgeless display produces sharp, crisp visuals and the metal finish provides extra durability. It also offers you four distinctive ways to work and play.
Powerful processors
Thin, light, quiet, and versatile. Powerful processors deliver great mobile performance, blazing-fast responsiveness, and amazing battery life. This feature-packed processor with built-in security is ready to take your productivity, creativity, and entertainment to the next level. What's more, processors empower you to unleash your imagination and explore the possibilities. -
Unique antenna hinge
Unreliable Wi-Fi connections are a regular frustration among PC users. The Lenovo Yoga 710 has addressed the problem by devising an antenna that physically integrates into the Yoga hinge, covering a greater surface area, and making signal strength stronger and more stable. -
Longer battery life
The Yoga 710 delivers more time of activity on a single charge. As the battery has been tested under real life conditions, you can be confident that it will last an entire workday without recharging. -
Sleek and lightweight
This ultraportable Lenovo Yoga 710 is designed for you to work and play - wherever life takes you. -
A robust design
The Yoga 710 is built to last. Its durable chassis is manufactured from aluminum, giving it a distinctive premium look and feel. -
Multiple ways to work and play
A PC when you need it, a tablet when you want it, and more. The Yoga 710 is extraordinarily adaptable. It features four different ways for you to do what you want: laptop, stand, tent, or tablet. Yoga 710's unique hinge and touchscreen display allows the screen to flip around 360 degrees, which means you can select the mode you use based on what you choose to do. -
Beautiful edgeless Full HD display
The vibrant FHD (1920 x 1080) edgeless display yields bright, detailed visuals for outstanding performance in gaming and multimedia. Ten-point multitouch technology provides a superior touch experience, greater responsiveness, and faster response times. In-plane switching (IPS) technology means the Yoga 710's display delivers clear visuals over a wide viewing angle - perfect for sharing content with friends. -
Solid State Drive (SSD) storage
With SSD storage included as standard, the Yoga 710 launches applications quicker, transfers files faster, and provides better protection if you accidentally drop your device. -
Dolby Audio
Get more from your entertainment with Dolby Audio. It enhances dialog, renders detail across a wide range of sounds, and maximizes the volume of your PC - without distortion. You'll also get to enjoy virtual surround sound from your PC speakers. -
Smile, swap, and sort - in seconds
Lenovo Photo Master 2.0 combines a modern photo library with powerful, easy-to-use navigation, and editing tools. Now, with features such as Auto Face Replace and Smart Event Sort, you can organize and optimize your photos to perfection.
- Lenovo Yoga 710-14ISK - 14" - Intel Core i7 - 6500U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Home 64-bit - English
- Processor
- Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 14" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 520
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- 4-cell - up to 8 hours
- Ambient light sensor, G-sensor
- Silver
- 32.2 cm x 22.3 cm x 1.73 cm
- 1.6 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 10 Home 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6500U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Dolby Audio Premium
- Audio Features
- Output: JBL
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - M.2 Card
- Technology
- 4-cell lithium polymer
- Capacity
- 53 Wh
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- USB 3.0 , USB 3.0 (Always On) , Micro-HDMI , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Silver
- Case Material
- Aluminum
- Integrated Options
- Administrator password, hard drive password, power-on password
- Included Accessories
- Power adapter
- RoHS
- Localization
- TopSeller
- 1.6 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
