Lenovo Yoga 710 i7-6500U 8GB 256 SSD Multi-Touch 14" Win 10 Home
Quicklinx: C9NKWS00 Mfr#: 80TY0000UK
  • Core i7
  • Bluetooth 4.0
  • IEEE 802.11n
Form meets function with the 14" Yoga 710. An innovative antenna hinge provides stronger, more stable Wi-Fi, while state-of-the-art processing and graphics deliver breathtaking performance, one of the fastest around. What's more, the edgeless display produces sharp, crisp visuals and the metal finish provides extra durability. It also offers you four distinctive ways to work and play.
  • Powerful processors
    Thin, light, quiet, and versatile. Powerful processors deliver great mobile performance, blazing-fast responsiveness, and amazing battery life. This feature-packed processor with built-in security is ready to take your productivity, creativity, and entertainment to the next level. What's more, processors empower you to unleash your imagination and explore the possibilities.
  • Unique antenna hinge
    Unreliable Wi-Fi connections are a regular frustration among PC users. The Lenovo Yoga 710 has addressed the problem by devising an antenna that physically integrates into the Yoga hinge, covering a greater surface area, and making signal strength stronger and more stable.
  • Longer battery life
    The Yoga 710 delivers more time of activity on a single charge. As the battery has been tested under real life conditions, you can be confident that it will last an entire workday without recharging.
  • Sleek and lightweight
    This ultraportable Lenovo Yoga 710 is designed for you to work and play - wherever life takes you.
  • A robust design
    The Yoga 710 is built to last. Its durable chassis is manufactured from aluminum, giving it a distinctive premium look and feel.
  • Multiple ways to work and play
    A PC when you need it, a tablet when you want it, and more. The Yoga 710 is extraordinarily adaptable. It features four different ways for you to do what you want: laptop, stand, tent, or tablet. Yoga 710's unique hinge and touchscreen display allows the screen to flip around 360 degrees, which means you can select the mode you use based on what you choose to do.
  • Beautiful edgeless Full HD display
    The vibrant FHD (1920 x 1080) edgeless display yields bright, detailed visuals for outstanding performance in gaming and multimedia. Ten-point multitouch technology provides a superior touch experience, greater responsiveness, and faster response times. In-plane switching (IPS) technology means the Yoga 710's display delivers clear visuals over a wide viewing angle - perfect for sharing content with friends.
  • Solid State Drive (SSD) storage
    With SSD storage included as standard, the Yoga 710 launches applications quicker, transfers files faster, and provides better protection if you accidentally drop your device.
  • Dolby Audio
    Get more from your entertainment with Dolby Audio. It enhances dialog, renders detail across a wide range of sounds, and maximizes the volume of your PC - without distortion. You'll also get to enjoy virtual surround sound from your PC speakers.
  • Smile, swap, and sort - in seconds
    Lenovo Photo Master 2.0 combines a modern photo library with powerful, easy-to-use navigation, and editing tools. Now, with features such as Auto Face Replace and Smart Event Sort, you can organize and optimize your photos to perfection.
Lenovo Yoga 710-14ISK - 14" - Intel Core i7 - 6500U - 8 GB RAM - 256 GB SSD - UK
Notebook - flip design
Operating System
Win 10 Home 64-bit - English
Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD
Display
14" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
4-cell - up to 8 hours
Ambient light sensor, G-sensor
Silver
32.2 cm x 22.3 cm x 1.73 cm
1.6 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - pick-up and return
Operating System
Windows 10 Home 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6500U / 2.5 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
8 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
14" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Dolby Audio Premium
Audio Features
Output: JBL
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260 - M.2 Card
4-cell lithium polymer
53 Wh
Run Time
Up to 8 hours
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
Interfaces Details
USB 3.0 , USB 3.0 (Always On) , Micro-HDMI , Headphone/microphone combo jack
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Silver
Case Material
Aluminum
Integrated Options
Administrator password, hard drive password, power-on password
Power adapter
RoHS
Localization
TopSeller
1.6 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
