Lenovo Yoga 300-11IBR N3710 4BG 500GB 11.6" Touch Windows 10
Quicklinx: C9MKWS00 Mfr#: 80M100FBUK
  • Pentium
  • Bluetooth 4.0
  • IEEE 802.11n
Tablet + PC in one device
The YOGA 300 redefines the essential laptop with 360 degrees of flexibility at an unbelievably low price. Whether for work, play or something in between, the YOGA 300 adapts to you with 4 ways to do almost anything: Laptop, Stand, Tent or Tablet.
  • 360º flip-and-fold design
    A PC when you need it, a tablet when you want it, and more. Easily change between four modes - laptop, stand, tent, and tablet. The secret: The 11" Lenovo Yoga 300's unique design and touchscreen display. It allows the screen to flip around 360º, which means you can select the mode you use based on what you choose to do.
  • Impressive performance for work and play
    Enjoy a PC with the Intel Pentium processor. Experience brilliant PC performance as you multitask effortlessly - communicate with friends and family, enjoy entertainment, and get your work done. Get the impressive performance and quality you've come to expect with an Intel Pentium processor. That's serious processing. Only with Intel inside.
  • Windows 10
    Windows 10 is the best combination of the Windows you already know, plus lots of great improvements you'll love. Technologies like InstantGo let you boot up and resume quickly, everything runs fast and smooth, and Windows 10 devices now have Battery Saver to automatically conserve power - so you can work longer and play harder. For total confidence, Windows 10 helps you stay up to date and has more built-in security features than ever for helping protect against malicious software.
  • Ultra thin, light, portable
    Starting at a mere 3.0 lbs and just 0.85" thin, the Yoga 300 is ultra portable - it's perfect for doers on the go. And with up to 8 hours on a standard battery, you can go all day without recharging.
  • Harmony
    Lenovo Harmony adapts to you by intuitively optimizing settings, making app recommendations by mode, and sharing statistics about how you use your device.
  • Stereo speakers
    The Yoga 300's speakers deliver rich stereo sound, while Dolby Home Theater provides an immersive audio experience.
  • McAfee LiveSafe free trial
    Keep your entire digital life secure with the comprehensive protection afforded by McAfee LiveSafe software. LiveSafe protects cross-device, through the cloud, and locally to ensure total security for your data and identity. Enjoy a free 30-day trial with purchase. Or, upgrade to the full version during the purchase process and enjoy peace-of-mind security from day one.
  • Lenovo DOit Apps
    Do more with your Yoga 300 with premium Lenovo applications like SHAREit, which lets you share files quickly without network charges or a WiFi connection. In addition, SYNCit backs up and restores your contacts and SMSs.
Lenovo Yoga 300-11IBR - 11.6" - Intel Pentium - N3710 - 4 GB RAM - 500 GB HDD - UK
Notebook - flip design
Operating System
Windows 10 Home
Intel Pentium N3710 / 1.6 GHz, up to 2.56 GHz / 2 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
500 GB HDD / 5400 rpm
Display
11.6" LED backlight touchscreen 1366 x 768 / HD
Graphics
Intel HD Graphics 405
Keyboard
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
2-cell
29.9 cm x 20.9 cm x 2.18 cm
1.4 kg
Environmental Standards
- EPEAT Climate+
Operating System
Windows 10 Home
Processor / Chipset
CPU
Max Turbo Speed
2.56 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
Integrated memory controller
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1333 MHz
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 5400 rpm
Display
11.6"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, microphone
Dolby Home Theater
Input
Keyboard, touchpad
Keyboard Layout
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 3160
Network Interface
Gigabit Ethernet
2-cell lithium polymer
30 Wh
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
Interfaces Details
2 x USB 2.0 , USB 3.0 , HDMI , Headphone/microphone combo jack , LAN
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Administrator password, hard drive password, power-on password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
1.4 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
