We focus on real product value, like the feature of a unique built-in projector and JBL surround sound with real bass. We care about users having the best experience with it. It is the best home entertainment centre and is also great for light work.
Performance for work and play with Intel inside
Wake in a flash, quickly open files and photos, and seamlessly switch between Apps without any delay. -
Revolutionary built-in projector
An industry first for a tablet, the Yoga Tablet 2 Pro boasts a new way to watch videos and movies: a built-in projector. Turn any dark room into a home theater while projecting up to a 50" image on any wall or screen. -
Immersive sound that stands on its own
The Yoga Tablet 2 Pro's integrated 8 W sound system gives you a rich, immersive audio experience - the likes of which has never been featured in a tablet form factor. Just check out these features: premium JBL front-facing, large-chamber speakers with subwoofer, Wolfson Master Hi-Fi audio processing and Dolby surround sound. -
Four ways to use your tablet
Yoga Tablet 2 Pro's innovative design places a battery cylinder and kickstand on the side of the device, shifting the center of gravity and opening up multiple ways to use it: Hold, Tilt, Stand, and Hang. That means there are four different ways to enjoy media content, games, and more. -
Epic battery life
Yoga Tablet 2 Pro keeps going over the long haul with its off-the-charts battery life. Its battery lasts many hours so you can go all day - and into the night - without recharging. The secret is Yoga Tablet's unique, cylinder-shaped side chamber allows more room for battery storage - and more time between charges. -
Ultra high-def display with a wide viewing angle
Yoga Tablet 2 Pro's dazzling 13.3" QHD (2560 x 1440) display delivers stunning high definition visuals - and you and your friends can enjoy them from a wide, 178 degree viewing angle thanks to the display's in-plane switching (IPS) technology. -
Advanced rear camera
Enjoy a new way to take beautiful photos with the Yoga Tablet 2 Pro's 8MP rear camera, which boasts an f2.2 wide-aperture lens, advanced glare-reducing glass, and a BSI 2 sensor.
- Lenovo Yoga Tablet 2 Pro-1380F Z0BC - tablet - Android 4.4 (KitKat) - 32 GB - 13.3"
- Product Type
- Tablet
- Operating System
- Display
- 13.3" IPS - 2560 x 1440 - Multi-Touch
- Processor
- Intel Atom Z3745 (Quad-Core)
- Processor Clock Speed
- 1.86 GHz
- Storage
- 32 GB eMMC
- RAM
- 2 GB
- Supported Flash Memory Cards
- microSD
- Wireless Connectivity
- 802.11a/b/g/n, Bluetooth 4.0
- Rear Camera
- 8 Megapixel focus: automatic
- Front Camera
- 1.6 Megapixel
- Navigation System
- GPS/GLONASS
- Battery Run Time
- Up to 15 hours
- 22.4 cm x 2.3 cm x 33.3 cm
- 950 g
- Platinum
- Manufacturer Selling Program
- TopSeller
- 1-year warranty
- Product Type
- Tablet
- Operating System
Display
- 13.3" IPS
- Resolution
- 2560 x 1440
- Touchscreen
- Multi-Touch
- 10-point multi-touch
- Processor
- Intel Atom Z3745
- 1.86 GHz
- Number of Cores
- Quad-Core
- Storage
- 32 GB eMMC
- RAM
- 2 GB - LPDDR3 SDRAM
- microSD
- Max Supported Capacity
- 64 GB
Communications
Rear Camera
- Sensor Resolution
- 8 Megapixel
- Focus Adjustment
- Automatic
Front Camera
- Sensor Resolution
- 1.6 Megapixel
Navigation System
- Receiver
- GPS/GLONASS
Multimedia
- Graphics
- Intel HD Graphics
- Audio
- Microphone, stereo speakers with subwoofer
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- 1 x headset , 1 x Micro-USB
- Technology
- Lithium Ion
- Capacity
- 9600 mAh
- Run Time
- Up to 15 hours
- Platinum
- Sensors
- Ambient light sensor, digital compass, magnetometer, G-sensor, hall sensor
- Miracast, built-in projector
- Vibrating Alert
- Included Accessories
- Power adapter
- RoHS
- TopSeller
- 22.4 cm
- 2.3 cm
- 33.3 cm
- 950 g
- Limited warranty - 1 year - pick-up and return
