In order to make a laptop lightweight and portable, many manufacturers have removed a number of the key features in order to save weight. Lenovo, however, have simply redesigned their range of laptops and the new Lenovo ThinkPad X260 laptop is the perfect blend of practicality, functionality and durability.
This sleek and stylish Lenovo laptop includes all-day battery life for usability on the go, great for those who have to hit their deadlines or who just can’t switch off on their commute or when they get back home.
With enterprise standard security and vast memory you can keep your files safe and secure, while the pre-installed Windows 7 PRO 64-bit operating system and Intel Core i5 fifth generation processor ensure that you get the response you need, and expect, from such a high quality laptop.
The 12.5-inch LED backlit display provides sharp images whether you’re working on a presentation or watching a film, making the ThinkPad X260 a truly multi-functional Ultrabook.
Having passed military-standard durability tests you can rest assured that the X260 laptop will be safe in your rucksack, and you can order yours online today complete with a three year warranty for peace of mind.
Thin and light
Thin and light, the X260 is ultraportable - without sacrificing anything in terms of ports, connectivity, or durability. -
Great keyboard
Full-sized and spill-resistant, the legendary ThinkPad ergonomic keyboard is renowned for its full array of keys, excellent feel, and TrackPoint pointing device. LED status indicators for camera, speaker, microphone, make working in dark environments effortless. -
Power Bridge technology
Combining an internal battery with an external hot-swappable battery, Power Bridge provides flexibility and maximum battery life. Swap batteries without powering down your laptop, using an extra travel battery to increase your time between charges. -
Additional ports
The X260 features an HDMI port to make it easy to attach external displays for presentations. Along with an USB port, this means connectivity and information sharing have never been easier. -
Ruggedness and durability
The laptop offers formidable ruggedness and durability against conditions such as high pressure, humidity, vibration, high temperature, temperature shock, low pressure, low temperature, solar radiation, fungus, salt fog, and dust.
- Lenovo ThinkPad X260 - 12.5" - Intel Core i5 - 6200U - 8 GB RAM - 192 GB SSD - UK
- Product Type
- Ultrabook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 192 GB SSD
- Display
- 12.5" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 30.55 cm x 20.85 cm x 2.03 cm
- 1.44 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
- Product Type
- Ultrabook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 192 GB SSD SATA 6Gb/s
Display
- 12.5" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC3245
- High Definition Audio
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
Wireless Broadband (WWAN)
- Generation
- WWAN upgradable
- Technology
- 3-cell
- Installed Qty
- 2
- Max Supported Qty
- 2
- Capacity
- 23 Wh
- Run Time With Included Additional Battery
- Up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Interfaces Details
- 3 x USB 3.0 , HDMI , Mini DisplayPort , LAN , Dock , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, ThinkVantage Product Recovery, Lenovo Solution Center, McAfee LiveSafe (30 days trial), SHAREit
- Case Material
- Glass-fibre reinforced plastic
- Dockable
- Security
- Administrator password, hard drive password, power-on password, ThinkEngine, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter, 3-cell Li-Ion 23Wh battery
- RoHS, GREENGUARD
- Localization
- TopSeller
- 1.44 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
