Lenovo X1 Carbon Skylake Core i5-6200U 4GB 192GB SSD Windows 7 Pro
Quicklinx: CFHRWS00 Mfr#: 20FB002VUK
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
A carbon fiber roll cage with reinforcement throughout makes the X1 Carbon Ultrabook ultralight, ultradurable and highly portable. Stay unplugged all day, but when needed, boost your battery up to 80% capacity in just 35 minutes.
  • An IT admin's dream
    ThinkPad X1 Carbon offers robust security features, including ThinkShutter, which covers the front-facing HD webcam, and match-on-chip fingerprint readers with anti-spoofing technology that helps safeguard company data while providing more secure authentication and log-in.
  • Audio so amazing you'll think it's live
    Speakers on the X1 Carbon deliver high-quality sound with Dolby Audio Premium, which energizes your entertainment with rich, powerful sound. It dynamically adjusts audio to deliver home theater quality in a virtual surround sound experience for all your entertainment. Boosted bass and enhanced volume turn it all up for sound that's loud and clear enough to share. And for times you need to plug in your headphones, enter a whole world of sound with Dolby Atmos, for an immersive experience that puts you inside the action.
  • Make your voice heard
    With Cortana Premium, you can speak commands to your ThinkPad X1 Carbon from 4 meters / 13 feet. The integrated 360-degree far field microphones ensure your voice is heard across the room. Wake your device with a simple phrase. Quickly and easily find files and calendar events. Even put your system into Modern Standby mode, which improves battery performance. So go ahead and speak your mind and boost your productivity at the same time.
  • Built to go on and on
    Like all ThinkPads, the X1 Carbon is tested against 12 military-grade requirements and more than 200 quality checks to ensure they run in extreme conditions. With a chassis constructed of four layers of reinforced carbon fiber and a magnesium alloy roll-cage for added strength, you'll trust this laptop to handle whatever life throws your way.
  • Flick your finger for privacy
    Minimize concerns about being watched or inadvertently turning on the webcam with ThinkShutter. This built-in sliding cover ensures front-facing camera privacy and security when you opt for the HD camera. It's easy to use and delivers strong protection.
Lenovo ThinkPad X1 Carbon (4th Gen) - 14" - Intel Core i5 - 6200U - 4 GB RAM - 192 GB SSD - UK
Ultrabook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
192 GB SSD
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
4-cell - up to 11 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader
33.3 cm x 22.9 cm x 1.645 cm
1.17 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
Ultrabook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
192 GB SSD M.2 SATA 6Gb/s
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, dual array microphone
Codec
CX11852
High Definition Audio
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Wireless Broadband (WWAN)
Generation
WWAN upgradable
4-cell lithium polymer
52 Wh
Run Time
Up to 11 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
Interfaces Details
3 x USB 3.0 , Mini DisplayPort , HDMI , OneLink+ connector , Headphone/microphone combo jack , LAN (on supplied cable)
Memory Card Reader
Yes (microSDXC UHS-II)
Software
Software Included
ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, ThinkVantage Product Recovery, Lenovo Solution Center, McAfee LiveSafe (30 days trial)
Case Material
Magnesium alloy, carbon fibre reinforced plastic
Dockable
Security
Administrator password, hard drive password, power-on password, RapidCharge, reset switch, 1 USB 3.0 (Always On), ThinkEngine, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, Lenovo OneLink+ Ethernet adapter
RoHS, GREENGUARD
Localization
TopSeller
1.17 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
