A carbon fiber roll cage with reinforcement throughout makes the X1 Carbon Ultrabook ultralight, ultradurable and highly portable. Stay unplugged all day, but when needed, boost your battery up to 80% capacity in just 35 minutes.
An IT admin's dream
ThinkPad X1 Carbon offers robust security features, including ThinkShutter, which covers the front-facing HD webcam, and match-on-chip fingerprint readers with anti-spoofing technology that helps safeguard company data while providing more secure authentication and log-in. -
Audio so amazing you'll think it's live
Speakers on the X1 Carbon deliver high-quality sound with Dolby Audio Premium, which energizes your entertainment with rich, powerful sound. It dynamically adjusts audio to deliver home theater quality in a virtual surround sound experience for all your entertainment. Boosted bass and enhanced volume turn it all up for sound that's loud and clear enough to share. And for times you need to plug in your headphones, enter a whole world of sound with Dolby Atmos, for an immersive experience that puts you inside the action. -
Make your voice heard!
With Cortana Premium, you can speak commands to your ThinkPad X1 Carbon from 4 meters / 13 feet. The integrated 360-degree far field microphones ensure your voice is heard across the room. Wake your device with a simple phrase. Quickly and easily find files and calendar events. Even put your system into Modern Standby mode, which improves battery performance. So go ahead and speak your mind and boost your productivity at the same time. -
Built to go on and on
Like all ThinkPads, the X1 Carbon is tested against 12 military-grade requirements and more than 200 quality checks to ensure they run in extreme conditions. With a chassis constructed of four layers of reinforced carbon fiber and a magnesium alloy roll-cage for added strength, you'll trust this laptop to handle whatever life throws your way. -
Flick your finger for privacy
Minimize concerns about being watched or inadvertently turning on the webcam with ThinkShutter. This built-in sliding cover ensures front-facing camera privacy and security when you opt for the HD camera. It's easy to use and delivers strong protection.
- Lenovo ThinkPad X1 Carbon (6th Gen) - 14" - Intel Core i7 - 8550U - 16 GB RAM - 512 GB SSD - 4G LTE-A - UK
- Product Type
- Ultrabook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (8th Gen) - 8550U / 1.8 GHz (4 GHz) / 8 MB Cache
- Memory
- 16 GB LPDDR3 (provided memory is soldered)
- Storage
- 512 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 14" LED backlight 2560 x 1440 / WQHD
- Graphics
- Intel UHD Graphics 620
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, NFC, Bluetooth 4.1, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE Advanced
- Service Provider
- Service not included
- Battery
- 3-cell - up to 19.3 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Black
- 32.35 cm x 21.71 cm x 1.595 cm
- 1.13 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- SAR
- 1.514 W/kg (body), 1.514 W/kg (limb)
- Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
- Product Type
- Ultrabook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8550U / 1.8 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
Storage
- Main Storage
- 512 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 2560 x 1440 (WQHD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 500 cd/m²
- Colour Gamut
- 100%
- Glossy, HDR (high dynamic range), Dolby Vision
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- ThinkShutter camera privacy
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3286
- High Definition Audio, Dolby Audio Premium
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Generation
- 4G
- Technology
- LTE Advanced
- Controller
- FIBOCOM L850-GL - M.2 Card
- Service Provider
- Technology
- 3-cell Lithium Ion
- Capacity
- 57 Wh
- Run Time
- Up to 19.3 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Slots
- 1 x Nano-SIM card (1 free)
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack , Lenovo Ethernet extension connector , Dock , LAN (on supplied cable)
- Memory Card Reader
- Yes (microSDXC UHS-II)
- Black
- Case Material
- Glass-fibre reinforced plastic, magnesium alloy, carbon fibre reinforced plastic, polyphenylene sulfide
- Dockable
- Security
- Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington mini security slot
- Included Accessories
- USB-C power adapter, ThinkPad Ethernet Extension Cable Gen 2
- RoHS
- SAR Value
- Localization
- TopSeller
- 1.13 kg
Sustainability Information
- ENERGY STAR Certified
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
Lenovo 3M 14.0W Privacy Filter | In Stock | £37.84 |
Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter | In Stock | £26.01 |
Lenovo 65W Standard AC Adapter USB-C | In Stock | £29.56 |
Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 | In Stock | £27.29 |
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £193.91 |
Kensington Security Cable Lock | In Stock | £23.65 |
Other bundles (11)
Lenovo HDMI to VGA Monitor Adapter | In Stock | £17.80 |
Lenovo USB3.0 To VGA/HDMI Adapter | In Stock | £63.85 |
Lenovo 2m HDMI Cable | In Stock | £17.02 |
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £40.20 |
Lenovo Professional Wireless Keyboard | In Stock | £53.21 |
Lenovo ThinkPad Ethernet Extension Adapter Gen 2 | In Stock | £24.84 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.07 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £26.08 |
Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor | In Stock | £252.52 |
Lenovo ThinkVision T23d 22.5" 1920x1200 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £233.56 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
