Lenovo X1 Carbon Broadwell Touch i7-5600U 8GB 256GB SSD 14" W10P
Quicklinx: BX92WS00 Mfr#: 20BS00AFUK
  • Core i7
  • Bluetooth 4.0
  • IEEE 802.11n
A carbon fiber roll cage with reinforcement throughout makes the X1 Carbon Ultrabook ultralight, ultradurable and highly portable. Stay unplugged all day, but when needed, boost your battery up to 80% capacity in just 35 minutes.
  • An IT admin's dream
    ThinkPad X1 Carbon offers robust security features, including ThinkShutter, which covers the front-facing HD webcam, and match-on-chip fingerprint readers with anti-spoofing technology that helps safeguard company data while providing more secure authentication and log-in.
  • Audio so amazing you'll think it's live
    Speakers on the X1 Carbon deliver high-quality sound with Dolby Audio Premium, which energizes your entertainment with rich, powerful sound. It dynamically adjusts audio to deliver home theater quality in a virtual surround sound experience for all your entertainment. Boosted bass and enhanced volume turn it all up for sound that's loud and clear enough to share. And for times you need to plug in your headphones, enter a whole world of sound with Dolby Atmos, for an immersive experience that puts you inside the action.
  • Make your voice heard!
    With Cortana Premium, you can speak commands to your ThinkPad X1 Carbon from 4 meters / 13 feet. The integrated 360-degree far field microphones ensure your voice is heard across the room. Wake your device with a simple phrase. Quickly and easily find files and calendar events. Even put your system into Modern Standby mode, which improves battery performance. So go ahead and speak your mind and boost your productivity at the same time.
  • Built to go on and on
    Like all ThinkPads, the X1 Carbon is tested against 12 military-grade requirements and more than 200 quality checks to ensure they run in extreme conditions. With a chassis constructed of four layers of reinforced carbon fiber and a magnesium alloy roll-cage for added strength, you'll trust this laptop to handle whatever life throws your way.
  • Flick your finger for privacy
    Minimize concerns about being watched or inadvertently turning on the webcam with ThinkShutter. This built-in sliding cover ensures front-facing camera privacy and security when you opt for the HD camera. It's easy to use and delivers strong protection.
Lenovo ThinkPad X1 Carbon (3rd Gen) - 14" - Intel Core i7 - 5600U - vPro - 8 GB RAM - 256 GB SSD - 4G LTE - UK
Ultrabook
Operating System
Win 10 Pro 64-bit
Platform Technology
Intel vPro Platform
Intel Core i7 (5th Gen) - 5600U / 2.6 GHz, up to 3.2 GHz / 4 MB Cache
8 GB DDR3L (provided memory is soldered)
Storage
256 GB SSD - TCG Opal Encryption 2
Display
14" LED backlight touchscreen 2560 x 1440 / WQHD
Graphics
Intel HD Graphics 5500
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
Wireless Broadband (WWAN)
4G LTE
Service Provider
Service not included
8-cell - up to 9.9 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader
33.1 cm x 22.71 cm x 1.846 cm
1.44 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
Ultrabook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (5th Gen) 5600U / 2.6 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Platform Technology
Intel vPro Platform
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
Storage
Main Storage
256 GB SSD M.2 SATA - TCG Opal Encryption 2
Display
14" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
2560 x 1440 (WQHD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
270 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
Gesture input support
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3232
High Definition Audio
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - M.2 Card
Network Interface
Gigabit Ethernet
Generation
4G
GSM, GPRS, EDGE, HSPA, LTE
Controller
Sierra Wireless EM7345 - M.2 Card
Service Provider
Navigation
Receiver
GPS
8-cell lithium polymer
50 Wh
Run Time
Up to 9.9 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
2 x USB 3.0 , Mini DisplayPort , HDMI , Headphone/microphone combo jack , LAN (on supplied cable) , OneLink connector , Lenovo Ethernet extension connector
Software
Software Included
Lenovo Solution Center, Lenovo Companion, McAfee LiveSafe (30 days trial), SHAREit
Case Material
Glass-fibre reinforced plastic, carbon fibre reinforced plastic, magnesium-aluminum alloy
Dockable
Security
Administrator password, hard drive password, power-on password, Intel Active Management Technology (iAMT), RapidCharge, reset switch, 1 USB 3.0 (Always On), ThinkEngine, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Network cable
RoHS
Localization
TopSeller
1.44 kg
Sustainability Information
ENERGY STAR Certified
BX92 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
