Lenovo V540-24IWL 23.8" All-In-One Intel Core i5-8265U 4GB 1TB Windows 10 Home 64-bit
Quicklinx: FDHSWS00 Mfr#: 10YS000GUK
  • Core i5
  • IEEE 802.11n
  • Bluetooth 4.0
Settle in for serious work with the Lenovo V540 all-in-one, a space-saving, secure desktop engineered for small business. Powered by a high-performance processor, this 23.8" AIO is ergonomically designed to ensure your comfort - as well as maximizing your productivity - when the workday extends into the evening.
  • Commanding performance
    Don't waste time. PCIe SSD storage and DDR4 memory mean speedy boot-ups, quick file loading, and faster system performance. The Lenovo V540 AIO's advanced processing delivers the power you need to conquer your to-do list.
  • Robust security
    The trusted platform module (TPM) encrypts all sensitive data on your Lenovo V540 to keep your business-critical information safe. You decide when your HD webcam is broadcasting thanks to its physical privacy cover.
  • Comfortable user experience
    Long hours? No problem. The 23.8" borderless, wide-view-angle FHD display delivers crisp visuals. The Ultra Low Noise and Low Blue Light certifications let you work longer, with less eyestrain and distraction.
  • Advanced ergonomics
    The ergonomic stand lets you tilt and swivel the display so it's most comfortable for you. And the Lenovo V540 is easy to install thanks to a latch design - and you can even use a VESA mount to attach it to a wall for increased desk space.
Lenovo V540-24IWL AIO - all-in-one - Core i5 8265U 1.6 GHz - 8 GB - HDD 1 TB - LED 23.8" - UK
Personal computer - all-in-one
Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) (Quad-Core)
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
HDD 1 TB - SATA 6Gb/s - 5400 rpm
Optical Storage
No optical drive
Card Reader
3 in 1
Monitor
23.8" - LED - 1920 x 1080 (Full HD) - 16:9
Graphics Controller
Intel UHD Graphics 620
Camera
GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
Keyboard
OS Provided
Windows 10 Home 64-bit Edition
Software Included
McAfee LiveSafe (30 days trial), Lenovo Vantage
54.1 cm x 21.4 cm x 45 cm
6.4 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers
Embedded Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
1.6 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 0 (empty)
Dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Optical Storage
No optical drive
Card Reader
3 in 1 card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
LED
Diagonal Size
23.8"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare, Wide Viewing Angle, borderless
Graphics Controller
Graphics Processor
Video Interfaces
HDMI
Audio Output
High Definition Audio
Speakers Included
2 x right / left channel
Camera
Camera
Resolution
720p
LED indicator, privacy shutter
Input Device
Keyboard, no mouse
Keyboard
Keyboard Name
Lenovo Calliope Keyboard
Wireless
RF
Localization & Layout
Audio Input
Dual array microphone
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Slots
2 (total) / 1 (free) x M.2 Card
2 x USB 3.1 Gen 2 (1 front, 1 rear) , 4 x USB 2.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x HDMI input , 1 x HDMI output , 1 x headphones/microphone (1 in front)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
TUV Rheinland Low Blue Light Certification, TUV Rheinland Ultra Low Noise Certification
TopSeller
Power adapter
Power Provided
65 Watt
Efficiency
88%
Operating System / Software
OS Provided
Windows 10 Home 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Dimensions & Weight Details
54.1 cm - 21.4 cm - 45 cm - 6.4 kg - with stand , 54.1 cm - 5.97 cm - 33.7 cm - 4.8 kg - without stand
54.1 cm
21.4 cm
45 cm
6.4 kg
Warranties (1)
FDHS Lenovo ePac On-site Repair from 1 to 3Yrs In Stock £64.29
Monitors (4)
FDHS Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor In Stock £202.02
FDHS Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor In Stock £454.54
FDHS Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor In Stock £336.70
FDHS Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £321.24
Keyboards and Mice (2)
FDHS Lenovo Professional Wireless Keyboard In Stock £53.47
FDHS Lenovo Essential Wired Keyboard and Mouse Combo - UK English In Stock £25.39
Other bundles (2)
FDHS Lenovo ThinkPad USB 3.0 Secure HDD-500GB In Stock £143.11
FDHS Kensington Security Cable Lock In Stock £23.65
