Robust, reliable, and secure, the Lenovo V530 AIO walks the walk and talks the talk. Powered by a robust processor, with high-speed memory and storage, it's designed with productivity and energy efficiency in mind. With its pin-sharp borderless display, this space-saving all-in-one will brighten up any desk - and your business prospects, too.
Optimized for IT - and business
Designed with IT and end-users in mind, the highly-responsive Lenovo V Series AIOs are easy to set up, deploy, use, and manage. Engineered for energy efficiency, they undergo stringent testing to ensure that they can perform in the most challenging environments. As well as helping you maximize productivity, they have robust security features to safeguard your critical data and built-in reliability that your business can count on. -
Your data is your business
Every V530 AIO is equipped with Smart USB Protection and TPM, or Trusted Platform Module. The first feature enables you to restrict the USB devices that can access your PC, the other provides hardware-based security should the system be tampered with. -
You can never be too careful
For extra peace of mind, you can open and close the webcam with the push of a button. So there's no need to spoil the nice, clean look of the borderless display with sticky tape or notes to cover up the camera. -
Great for any business & workspace
At home in almost any environment, V530 AIO's durability and reliability mean good value for any business.
- Lenovo V530-24ICB AIO - all-in-one - Core i5 9400T 1.8 GHz - 8 GB - HDD 1 TB - LED 23.8" - UK
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i5 (9th Gen) 9400T / 1.8 GHz (3.4 GHz) (6-core)
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 5400 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- 3 in 1
- Monitor
- 23.8" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
- Graphics Controller
- Intel UHD Graphics 630
- Camera
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 54.27 cm x 22.795 cm x 43.74 cm
- 7 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- All-in-one - with monitor stand
- Built-in Devices
- Stereo speakers
- Embedded Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 1.8 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel B360
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 5400 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer
Card Reader
- 3 in 1 card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- LED
- Touchscreen
- Yes (10-point multi-touch)
- Diagonal Size
- 23.8"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare, Wide Viewing Angle, borderless, Advanced In-Cell Touch (AIT) technology
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution
- 720p
- Built-in microphone, LED indicator, privacy shutter
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Lenovo Calliope Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- Lenovo Calliope Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111G
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 3165
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Wake on LAN (WoL)
- Slots
- 2 (total) / 0 (free) x M.2 Card
- 1 x USB 3.1 Gen 2 , 3 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x HDMI input , 1 x HDMI output , 1 x headphones/microphone , 2 x USB 3.1 Gen 1 (1 front, 1 bottom)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- TUV Rheinland Low Blue Light Certification
- TopSeller
- Power adapter
- Voltage Required
- Power Provided
- 90 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Dimensions & Weight Details
- 54.27 cm - 22.795 cm - 43.74 cm - 7 kg - with stand , 54.27 cm - 5.41 cm - 36.74 cm - 5.6 kg - without stand
- 54.27 cm
- 22.795 cm
- 43.74 cm
- 7 kg
Lenovo ePac On-site Repair from 1 to 3Yrs | In Stock | £64.29 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.20 |
Lenovo 2m HDMI Cable | In Stock | £17.02 |
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £40.20 |
Lenovo Professional Wireless Keyboard | In Stock | £53.21 |
Kensington Security Cable Lock | In Stock | £23.65 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £26.08 |
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £201.00 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor | In Stock | £336.70 |
Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor | In Stock | £314.26 |
Lenovo 100 Headset on ear wired - USB black for IdeaPad 3 ThinkCe | In Stock | £35.79 |
Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.88 |
Lenovo Thinkvision MC50 Monitor Webcam | In Stock | £51.40 |
