Robust, reliable, and secure, the Lenovo V530 AIO walks the walk and talks the talk. Powered by the latest Intel processors, with high-speed memory and storage, it's designed with productivity and energy efficiency in mind. With its pin-sharp borderless display, this space-saving all-in-one will brighten up any desk - and your business prospects, too.
Optimized for IT - and business
Designed with IT and end-users in mind, the highly-responsive Lenovo V Series AIOs are easy to set up, deploy, use, and manage. Engineered for energy efficiency, they undergo stringent testing to ensure that they can perform in the most challenging environments. As well as helping you maximize productivity, they have robust security features to safeguard your critical data and built-in reliability that your business can count on. -
The power to empower your business
When it comes to performance and responsiveness, the Lenovo V530 AIO punches way above its starting weight of 5.6 kg. With up to 8th Gen Intel Core i7 processing power and 16 GB of high-speed memory, plus a choice of storage options, your productivity and efficiency levels are set to soar. -
The powerful Lenovo V530 AIO makes multitasking a breeze
Every V530 AIO is equipped with Smart USB Protection and TPM, or Trusted Platform Module. The first feature enables you to restrict the USB devices that can access your PC, the other provides hardware-based security should the system be tampered with. -
You can never be too careful
For extra peace of mind, you can open and close the webcam with the push of a button. So there's no need to spoil the nice, clean look of the 21.5" borderless display with sticky tape or notes to cover up the camera. -
Great for any business & workspace
At home in almost any environment, V530 AIO's durability and reliability mean good value for any business. It's great for IT managers, too, who can tap into Lenovo Vantage tools to help optimize system performance and protect data. And the rear cable holder is perfect for those who like a neat desk.
- Lenovo V530-22ICB AIO - all-in-one - Core i5 9400T 1.8 GHz - 8 GB - HDD 1 TB - LED 21.5" - UK
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i5 (9th Gen) 9400T / 1.8 GHz (3.4 GHz) (6-core)
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 8 GB (installed) / 16 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 5400 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- 3 in 1
- Monitor
- 21.5" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
- Graphics Controller
- Intel UHD Graphics 630
- Camera
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- McAfee LiveSafe (30 days trial), Lenovo App Explorer, Lenovo Vantage
- Black
- 49.02 cm x 22.8 cm x 40.87 cm
- 6.1 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- All-in-one - with monitor stand
- Built-in Devices
- Stereo speakers
- Embedded Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 1.8 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel B360
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 5400 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer
Card Reader
- 3 in 1 card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- LED - IPS
- Touchscreen
- Yes (10-point multi-touch)
- Diagonal Size
- 21.5"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare, Wide Viewing Angle, borderless, Advanced In-Cell Touch (AIT) technology
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI
Audio Output
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution
- 720p
- LED indicator, privacy shutter
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
Audio Input
- Microphone
- Ethernet Controller
- Realtek RTL8111G
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 3165
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Wake on LAN (WoL)
- Slots
- 2 (total) / 1 (free) x M.2 Card
- 1 x USB 3.1 Gen 2 , 2 x USB 3.1 Gen 1 , 3 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x HDMI input , 1 x HDMI output , 1 x headphones/microphone
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- TopSeller
- Power adapter
- Voltage Required
- Power Provided
- 90 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Dimensions & Weight Details
- 49.02 cm - 22.8 cm - 40.87 cm - 6.1 kg - with stand , 49.02 cm - 5.5 cm - 33.88 cm - 4.6 kg - without stand
- 49.02 cm
- 22.8 cm
- 40.87 cm
- 6.1 kg
Lenovo ePac On-site Repair from 1 to 3Yrs | In Stock | £64.29 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.20 |
Lenovo 2m HDMI Cable | In Stock | £17.02 |
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £41.29 |
Lenovo Professional Wireless Keyboard | In Stock | £53.21 |
Kensington Security Cable Lock | In Stock | £23.65 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £201.00 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
