Lenovo V520S Core i3-7400 4GB 128GB SSD Windows 10
Quicklinx: CWLLWS00 Mfr#: 10NM0024UK
  • Core i3
With powerful processor and advanced memory - the Lenovo V520S small form factor is designed to boost your productivity. Combined with performance-enhancing hard drive - you have speed and power at your fingertips as you handle large files, create rich content, and stay in touch. With 4 forward-facing USB ports, you can connect your peripherals, and adapt as your business grows. Your V520S small form factor delivers security, simplicity, and productivity - helping you drive your business forward.
  • Powerful performance
    Make business-boosting productivity your first choice with powerful processor - together with fast hard drive, advanced memory to power up in a flash, load files fast and avoid frustrating delays.
  • Future ready
    You're fully equipped for easy upgrade to Intel Optane memory - enabling you to get even more amazing performance and responsiveness without compromising on storage.
  • Enhanced security
    With smart USB protection for preventing sensitive business data from leaking - you have the reassurance of optimized security features.
Lenovo V520S-08IKL - SFF - Core i3 7100 3.9 GHz - 4 GB - SSD 128 GB - UK
Personal computer - small form factor
Intel Core i3 (7th Gen) 7100 / 3.9 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Smart Cache
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 128 GB - SATA 6Gb/s - 2.5" (7 mm)
Optical Storage
DVD-Writer
Card Reader
7 in 1
Graphics Controller
Intel HD Graphics 630
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Lenovo Companion, Lenovo ID
29.05 cm x 34.35 cm x 8.9 cm
4.75 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
Small form factor
Embedded Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.9 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel B250
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
SSD - 2.5" (7 mm)
1 x 128 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
DVD-Writer - SATA
Card Reader
7 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI, DisplayPort
Max Monitors Supported
3
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Lenovo Calliope Keyboard
USB
Localization & Layout
Mouse
Mouse Name
Lenovo Calliope Mouse
USB
Ethernet Controller
Realtek RTL8111GN
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2.5" x 1/8H
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x1 - low-profile , 2 (total) / 2 (free) x M.2 Card
6 x USB 3.0 (4 front, 2 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 2 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x VGA , 1 x DisplayPort , 1 x HDMI
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
TopSeller
Power supply
Power Provided
180 Watt
Efficiency
85%
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.1
29.05 cm
34.35 cm
8.9 cm
4.75 kg
