Lenovo V330-14IKB Intel Core i5-8250U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: FFVPWS00 Mfr#: 81B000VEUK
  • Core i5
  • IEEE 802.11n
Remarkable value, impressive results
Value-conscious without sacrificing performance, the stylish and reliable Lenovo V330 14-inch laptop helps you focus on running a successful business. Powerful Intel® technology keeps you working productively. Optimized for security, flexibility, and reliability, it will reduce the burden on your IT team. Your work is sure to impress with this laptop for no-nonsense business professionals.
Keeps IT departments as happy as their users
Simple. Flexible. Compatible. The V330 is easy for IT to deploy, offering the simplicity of Windows 10 Pro, the flexibility of an Ultrabay drive that can house an optical drive or an additional battery, and the hardware compatibility of multiple USB-C and USB 3.0 ports.
Reliable. Repairable. Secure. The V330 makes IT maintenance easy, too. It's reliable—as shown by the series of rigorous tests it undergoes against shocks, drops, and other extremes—and secure, thanks to its physical camera shutter, Touch Type fingerprint reader, and integrated TPM 1.2 firmware. And IT can rest easy with the Lenovo Sealed Battery Warranty, offering three-year coverage for non-CRU batteries.
Additional details on these features are available below.
Work and play better
With the widescreen antiglare display with up to FHD (1920 x 1080) resolution, you'll enjoy rich visuals no matter what you’re doing. Get your work done. Be creative. Watch a movie. The display opens 180 degrees, making it simple to share and collaborate or just get comfortable using your laptop the way you want.
Working anywhere just got easier
The ergonomic keyboard on the V330 was engineered for comfort and typing accuracy. The large touchpad makes it even easier to be productive wherever you are – no mouse required. And with plenty of life in its QuickCharge battery, plus a rechargeable Ultrabay battery for additional battery life, you’ll get a lot of uninterrupted time without worrying about electrical outlets.
Pin-stripe suit optional
The V330 exudes professionalism, thanks to its contemporary style, iron gray-color exterior, and thin design with narrow bezels. Put a sharp-looking face on your business.
Put it through the ringer – we did
The V330 was built to last, and we have the test scores to prove it. We tested it for reliability and durability against eight extreme conditions: shock test; vibration test; keyboard in-system test; hinge life test; fan reliability test; panel scuff test; operating temperature test; and pressure test. This laptop is ready for whatever conditions your business can put it through. And to put your mind further at ease, the V330 is backed by a one- or two-year base warranty, with up to three years total available (see the Services tab for information on Extensions).
Don't forget to smile
Whether you're meeting with a prospective new client or your colleagues around the world, the V330 has you covered for a superb video-conferencing experience. Stereo speakers deliver rich sound (which is great for music and movies, too). And the HD webcam ensures visuals so crisp and clear you’ll feel like you're in the same room with meeting participants.
Laugh at would-be data thieves – including gravity
The V330 features the integrated firmware, Trusted Platform Module (TPM), which works in conjunction with Windows 10 Pro Bitlocker to encrypt your data and your passwords. Active Protection System (APS) locks the hard drive when it detects a fall, protecting against data loss (not available for SSDs). And the physical camera shutter helps protect your privacy – simply close it to keep the camera from seeing anything.
Go ahead – forget your password
With the option of an integrated Touch Type fingerprint reader, you'll never need to remember your password again! Simply touch the fingerprint scanner to access your V330, or use your face with Windows Hello facial recognition software and login automatically. No need to worry about remembering passwords again.
Let your assistant do the heavy lifting
Start with Windows 10 Pro for your V330, which includes your own personal assistant, Cortana. With an Intel® Core™ processor, you'll get powerful performance and speed. Plus, you’ll never have to hunt for files or photos or meetings again – let Cortana do the work for you! Integrate Cortana with your calendar and you can even search by when and whom you worked on a file with, rather than having to remember file names.
  • Keeps IT departments as happy as their users
    Simple. Flexible. Compatible. The V330 is easy for IT to deploy, offering the simplicity of Windows 10 Pro, the flexibility of an Ultrabay drive that can house an optical drive or an additional battery, and the hardware compatibility of multiple USB-C and USB 3.0 ports. Reliable. Repairable. Secure. The V330 makes IT maintenance easy, too. It's reliable-as shown by the series of rigorous tests it undergoes against shocks, drops, and other extremes-and secure, thanks to its physical camera shutter, Touch Type fingerprint reader, and integrated TPM 1.2 firmware.
  • Work and play better
    With the widescreen antiglare IPS display with up to FHD (1920 x 1080) resolution, you'll enjoy rich visuals no matter what you're doing. Get your work done. Be creative. Watch a movie. The display opens 180 degrees, making it simple to share and collaborate or just get comfortable using your laptop the way you want.
  • Working anywhere just got easier
    The ergonomic keyboard on the V330 was engineered for comfort and typing accuracy. The large touchpad makes it even easier to be productive wherever you are-no mouse required. And with plenty of life in its QuickCharge battery, plus a rechargeable Ultrabay battery for additional battery life, you'll get a lot of uninterrupted time without worrying about electrical outlets.
  • Pin-strip suit optional
    The V330 exudes professionalism, thanks to its contemporary style, two-color exterior, and thin design with narrow bezels. Put a sharp-looking face on your business.
  • Don't forget to smile
    Whether you're meeting with a prospective new client or your colleagues around the world, the V330 has you covered for a superb video-conferencing experience. Stereo speakers deliver rich sound (which is great for music and movies, too). And the HD webcam ensures visuals so crisp and clear you'll feel like you're in the same room with meeting participants.
  • Laugh at would-be data thieves-including gravity
    The V330 features the integrated firmware, Trusted Platform Module (TPM), which works in conjunction with Windows 10 Pro Bitlocker to encrypt your data and your passwords. Active Protection System (APS) locks the hard drive when it detects a fall, protecting against data loss (not available for SSDs). And the physical camera shutter helps protect your privacy-simply close it to keep the camera from seeing anything.
  • More secure, more convenient
    With the option of an integrated Touch Type fingerprint reader, logging into your V330 couldn't be easier-or more secure. Simply touch the fingerprint scanner and you're good to go. Alternatively, with Windows Hello facial recognition software, all you need to do is smile.
Lenovo V330-14IKB - 14" - Intel Core i5 8250U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
8 GB DDR4 (1 x 4 GB + 4 GB (soldered))
Storage
256 GB SSD
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
2-cell - up to 6 hours
Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Iron grey
34.3 cm x 24.7 cm x 2.03 cm
1.7 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Integrated memory controller
RAM
8 GB (1 x 4 GB + 4 GB (soldered))
Max RAM Supported
20 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
256 GB SSD M.2 PCIe - SanDisk
Display
14" - TN
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
Privacy shutter
Sound
Stereo speakers, microphone
Dolby Audio
Input
Keyboard, touchpad
Keyboard Layout
Spill-resistant, multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 3165 - M.2 Card
Network Interface
Gigabit Ethernet
2-cell Lithium Ion
30 Wh
Run Time
Up to 6 hours
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
2 x USB 3.0 , USB-C 3.1 Gen 1 , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , HDMI , VGA , LAN , Headphone/microphone combo jack
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Iron grey
Case Material
Polycarbonate ABS
Security
Administrator password, hard drive password, power-on password
Theft/Intrusion Protection
Security Slot Type
Kensington mini security slot
Power adapter
RoHS
Localization
1.7 kg
Sustainability Information
ENERGY STAR Certified
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
FFVP Lenovo TP 90W AC Adapter for X1 Carbon In Stock £40.25
FFVP Lenovo ThinkPad 65W AC Adapter (Slim Tip) In Stock £34.46
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
FFVP Lenovo 3Y On Site Warratny In Stock £52.86
