Lenovo V130-15IKB Intel Core i5-7200U 4GB 128GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: F58QWS00 Mfr#: 81HN00NPUK
Display Size: 15.6in
Processor Model: I5-7200U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 128GB
  • Core i5
  • IEEE 802.11n
More than 50 in stock
£427.67 ex VAT
£513.20 inc VAT
The V130 15.6" laptop delivers great performance in a patterned, textured cover that bespeaks modern style. A simple, clean design features a large, one-piece touchpad and hinges that open 180 degrees - perfect for collaborating. Powerful Intel technology keeps you working productively, while enhanced security protects your critical data.
  • An IT admin's dream
    The V130 small-business laptop is perfectly portable - yet it features powerful processing, so it's a cinch to work with anywhere.
  • No matter what your angle
    The V130 delivers rich visuals no matter what you're doing. Complete your project. Be creative. Watch a movie. The 15.6" screen opens 180 degrees, making it simple to share and collaborate, or just get comfortable with your laptop at the angle you want. And with stereo speakers and Dolby Audio no matter what you're listening to, it's sure to sound as good as it looks.
  • Think outside the cubicle
    The full-sized, ergonomic keyboard on the V130 was engineered for comfort and typing accuracy. The large touchpad makes it even easier to be productive wherever you are - no mouse required - and the one-piece design looks sleek. This keyboard is also spill-resistant, so you can go about your business without concern for the little mishaps of daily life.
  • Built for business, tested for life
    V Series laptops undergo reliability and durability checks to ensure they run smoothly for years to come. From withstanding shocks and vibrations to enduring the rigors of daily handling. From hinge-life testing to fan reliability, operating temperatures, pressure tests, and more.
Lenovo V130-15IKB - 15.6" - Core i5 7200U - 4 GB RAM - 128 GB SSD - QWERTY UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
4 GB DDR4 (provided memory is soldered)
Storage
128 GB - M.2 SSD
Optical Drive
DVD-Writer
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
2-cell - up to 6 hours
Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
Iron grey
37.5 cm x 25.3 cm x 2.23 cm
1.8 kg
Environmental Standards
ENERGY STAR Qualified
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Integrated memory controller
RAM
4 GB (provided memory is soldered)
Max RAM Supported
12 GB
DDR4 SDRAM
Speed
2133 MHz - 2133 MHz
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
128 GB SSD - (M.2) PCIe - Toshiba
Optical Drive
DVD-Writer - tray
Display
15.6" - TN
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, microphone
Dolby Audio
Input
Keyboard, touchpad
Keyboard Layout
QWERTY UK
Numeric Keypad
Spill-resistant, multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 3165 - M.2 Card
Network Interface
Gigabit Ethernet
2-cell Lithium Ion
30 Wh
Run Time
Up to 6 hours
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
2 x USB 3.0 , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Iron grey
Case Material
Polycarbonate ABS
Security
Administrator password, hard drive password, power-on password
Theft/Intrusion Protection
Security Slot Type
Kensington mini security slot
Power adapter
RoHS
Localization
1.8 kg
ENERGY STAR Certified
Software applications
Lenovo V130-15IKB Intel Core i5-7200U 4GB 128GB SSD 15.6 Bundle deal on Lenovo V130-15IKB Intel Core i5-7200U 4GB 128GB SSD 15.6" Windows 10 Professional 64-bit
£615.31
saving £8.33
£527.43
F58Q Lenovo Optical 3-button W/Mouse USB In Stock £13.60
Optical Storage: DVD-Writer
Graphics: Intel HD Graphics 620
Hard Drive Type: SSD
Brand: Lenovo
Price Range Ex VAT: 300 - 500
