From powerful processing and memory to a performance-enhancing keyboard, the reliable Lenovo V110 can meet your business needs today - and in the future. Affordably-priced, this light laptop has a modern design and a high-resolution screen that works great outdoors and indoors.
Powerful performance
Enjoy advanced standard for PC performance with powerful processors. Blazingly fast and feature-packed with built-in security, they are ready to take your productivity, creativity, and entertainment to the next level. -
Antiglare display
The Lenovo V110 has a crisp display, delivering bright visuals in widescreen format. It also comes with antiglare technology which can help lower the risk of eye strain. -
Light yet robust
Thin and light, the Lenovo V110 is designed for you to work from anywhere. Plus, there's no gap between the keys on the keyboard. So the build-up of dust and dirt, which can degrade performance over time, is vastly reduced. -
Lay-flat hinge
The Lenovo V110's hinge can flip up to 180 degrees - ideal for when you need to share your screen with others.
- Lenovo V110-15IKB - 15.6" - Intel Core i5 - 7200U - 4 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
- Memory
- 4 GB DDR4 (provided memory is soldered)
- Storage
- 128 GB SSD
- Optical Drive
- DVD-Writer
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 620
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 4-cell - up to 6 hours
- Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip
- Black texture
- 38 cm x 26.2 cm x 2.29 cm
- 1.9 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 4 GB (provided memory is soldered)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD 2.5" SATA 6Gb/s
- Optical Drive
- DVD-Writer - tray
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 0.3 Megapixel
- Sound
- Speaker, microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Realtek RTL8821AE - M.2 Card
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 32 Wh
- Run Time
- Up to 6 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1/USB 3.0 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Lenovo Companion, Lenovo Settings, McAfee LiveSafe (30 days trial)
- Black texture
- Case Material
- Polycarbonate ABS
- Security
- Administrator password, hard drive password, power-on password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington mini security slot
- Included Accessories
- Power adapter
- RoHS
- Localization
- 1.9 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
