Lenovo V110-15IKB i5 7200U 4GB 128GB 15.6" Win10 Home
Quicklinx: D3VFWS00 Mfr#: 80TH0013UK
  • Core i5
  • IEEE 802.11n
From powerful processing and memory to a performance-enhancing keyboard, the reliable Lenovo V110 can meet your business needs today - and in the future. Affordably-priced, this light laptop has a modern design and a high-resolution screen that works great outdoors and indoors.
  • Powerful performance
    Enjoy advanced standard for PC performance with powerful processors. Blazingly fast and feature-packed with built-in security, they are ready to take your productivity, creativity, and entertainment to the next level.
  • Antiglare display
    The Lenovo V110 has a crisp display, delivering bright visuals in widescreen format. It also comes with antiglare technology which can help lower the risk of eye strain.
  • Light yet robust
    Thin and light, the Lenovo V110 is designed for you to work from anywhere. Plus, there's no gap between the keys on the keyboard. So the build-up of dust and dirt, which can degrade performance over time, is vastly reduced.
  • Lay-flat hinge
    The Lenovo V110's hinge can flip up to 180 degrees - ideal for when you need to share your screen with others.
Lenovo V110-15IKB - 15.6" - Intel Core i5 - 7200U - 4 GB RAM - 128 GB SSD - UK
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
4 GB DDR4 (provided memory is soldered)
Storage
128 GB SSD
Optical Drive
DVD-Writer
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Keyboard
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
4-cell - up to 6 hours
Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
Black texture
38 cm x 26.2 cm x 2.29 cm
1.9 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (7th Gen) 7200U / 2.5 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Integrated memory controller
RAM
4 GB (provided memory is soldered)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
128 GB SSD 2.5" SATA 6Gb/s
Optical Drive
DVD-Writer - tray
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Resolution
0.3 Megapixel
Sound
Speaker, microphone
High Definition Audio
Input
Keyboard, touchpad
Keyboard Layout
Numeric Keypad
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Realtek RTL8821AE - M.2 Card
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
32 Wh
Run Time
Up to 6 hours
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
Interfaces Details
USB 3.1 Gen 1/USB 3.0 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
Lenovo Companion, Lenovo Settings, McAfee LiveSafe (30 days trial)
Black texture
Case Material
Polycarbonate ABS
Security
Administrator password, hard drive password, power-on password
Theft/Intrusion Protection
Security Slot Type
Kensington mini security slot
Power adapter
RoHS
Localization
1.9 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
