Lenovo USB-C To USB-C Cable - 2m
Quicklinx: FCDSWS00 Mfr#: 4X90Q59480
More than 50 In Stock
£31.44 ex VAT
£37.72 inc VAT
The Lenovo USB-C to USB-C Cable 2m makes it easy to connect your USB-C notebook with other USB-C accessories and displays that are slightly out of reach. It supports a 5Gbps data rate, 20V/3A 60W power, and can be used with USB-C Docks, USB-C monitors with 4K video, and other USB-C devices. It is extra-long at 2m (6'6"), with a cable management strap.
  • Efficient connectivity
    This Lenovo USB cable is designed to provide a reliable connection between your devices, ensuring efficient data transfer and power delivery. With a rated current of 3 A and a voltage of 20 V, it supports fast charging and secure data synchronization for a seamless user experience.
  • Universal compatibility
    Featuring a 24 pin USB-C connector on both ends, this cable offers versatile connectivity options. It's compatible with a wide range of devices, making it a practical choice for connecting smartphones, tablets, laptops, and more. Its compatibility with Chromebook further enhances its utility in diverse environments.
Lenovo - USB cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB cable
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
20 V
Rated Current
3 A
Works With Chromebook
1-year warranty
USB cable
Rated Voltage
20 V
Rated Current
3 A
Length
2 m
Connector
24 pin USB-C - male
24 pin USB-C - male
1-year warranty
Brand: Lenovo
