Ample networking and storage capacity
With up to 16 TB SATA storage and eight Ethernet ports, the TS140 offers storage and scalability for businesses large and small.
Resourceful manageability features
The TS140 makes clever use of Intel AMT 9.0 to provide out-of-band, cost-effective, remote management of end-user environments - regardless of the managed server's status. Intuitive and secure, the web console works directly out of the box to give point-and-click management tools perfect for branch offices or remote deployments with limited IT resources.
Whisper-quiet, energy-efficient operation
At 26 dB, the acoustics of the TS140 are less noise than you'll find in a typical library. Plus, it's ENERGY STAR-certified, so it's easy on the environment and easy on your power bills.
True server-class features
Rely on features like ECC memory, enterprise-class hard drives, and built-in RAID for maximum uptime - the TS140 is designed for 24 x 7 run times and true server reliability. And it's certified for MSP support with ecosystem vendors like Level Platforms, Kaseya, and N-able.
Superb value
With its attractive price points (it costs about as much as a typical desktop PC) and low operating costs, the TS140 is highly affordable for the features and functionality it offers.
Lenovo NAS storage portfolio
Choose from three network storage options, each powered by enterprise-class LenovoEMC technology for secure, fast storageand sharing of your important data.
Main Features:
Lenovo ThinkServer TS140 Tower Server
Intel Xeon Quad Core E3 (1226 v3) 3.3GHz Processor with 8MB Cache
4GB (1x4GB) 1600MHz DDR3 UDIMM memory
1TB (1x1TB) SATA Hard Drive
Slim DVD±RW Drive
Integrated Intel HD Graphics P4600
Integrated 10/100/1000 Gigabit Ethernet
RAID100 onboard (0/1/10/5)
Tech Specification
CPU Processor: Intel Xeon (Quad Core) E3 (1226 v3) 3.3GHz 8MB (L3 Cache)
CPU Bus Speed: 1.6GHz
Socket: LGA1150
Processors (Max): 1 (1)
Chipset: Intel C226
PCI 32 bit: 1 x PCI Slots
PCI Express Slot: 2 x PCI Express x16, 1 x PCI Express x1 Slots
Memory (Maximum): 4GB (32GB) 1600MHz DDR3
Memory Slots (Free): 4 x DIMM
Hard Drive Interface: SATA
Hard Disk: 1000GB (1 x 1000GB) 7200RPM
Internal Expansion Bays: 4 x 3.5 inch
RAID Format: RAID 0, 1, 5, 10
Optical Drive Type: DVD±RW
Graphics Device: Intel HD Graphics
System Management: Intel Advanced Management Technology (AMT) 9.0
Security: Power-on password; Boot sequence control; Boot without keyboard, mouse, diskette; Serial port I/O control; USB port disablement (front or all)
Compliance certifications: GREENGUARD certified, Energy Star Server 1.1 qualified, RoHS-compliant
Power Supply: 450W
Voltage/Power/Frequency: 100 to 240V AC / 50 to 60Hz
Colour: Black
VGA Port: 1 x 15-pin VGA
USB Ports: 6 x USB 3.0, 2 x USB 2.0
Serial Ports: 1 x 9-pin RS-232
RJ-45 Ports: 1 x RJ-45
Microphone In Port: 1 x Microphone In
Audio Line In Port: 1 x Audio Line In
Audio Line Out Ports: 1 x Audio Line Out
DisplayPort: 2 x DisplayPort
Network Card: Ethernet 10/100/1000MBps
Productivity boost
Thanks to the increased performance of the latest Intel Xeon processor, with Turbo Boost 2.0, onboard RAID 0/1/10/5 data protection, and powerful HD graphics performance, the TS140 has the power and speed to handle your workload with ease - while keeping your data safe. -
With up to 16 TB SATA storage and eight Ethernet ports, the TS140 offers storage and scalability for businesses large and small. -
The TS140 makes clever use of Intel AMT 9.0 to provide out-of-band, cost-effective, remote management of end-user environments - regardless of the managed server's status. Intuitive and secure, the web console works directly out of the box to give point-and-click management tools perfect for branch offices or remote deployments with limited IT resources. -
At 26 dB, the acoustics of the TS140 are 40 percent quieter than previous generations and impressively quiet for any server - that's less noise than you'll find in a typical library. Plus, it's ENERGY STAR-certified, so it's easy on the environment and easy on your power bills. -
Rely on features like ECC memory, enterprise-class hard drives, and built-in RAID for maximum uptime - the TS140 is designed for 24 x 7 run times and true server reliability. And it's certified for MSP support with ecosystem vendors like Level Platforms, Kaseya, and N-able. -
Superb value
With its attractive price points (it costs about as much as a typical desktop PC) and low operating costs, the TS140 is highly affordable for the features and functionality it offers. -
Choose from three network storage options, each powered by enterprise-class LenovoEMC technology for secure, fast storage and sharing of your important data.
- Lenovo ThinkServer TS140 - tower - Xeon E3-1226V3 3.3 GHz - 4 GB - HDD 1 TB
- Server - tower - power-on password, serial port I/O control, USB port control, boot sequence control, Intel Active Management Technology (iAMT), boot without keyboard or mouse or diskette
- Height (Rack Units)
- 4U
- Localisation
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1226V3 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC
- Storage Controller
- RAID (SATA 6Gb/s) (ThinkServer RAID 100)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics P4600
- Audio Output
- Integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- No operating system
- Raven black
- 17.5 cm x 43.1 cm x 37.5 cm
- 13 kg
- Environmental Standards
- ENERGY STAR Qualified
- Server
- Product Form Factor
- Tower - 4U
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 1-way
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 1
- Raven black
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E3-1226V3
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel C226
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total)
- Unbuffered
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x RAID - integrated
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- ThinkServer RAID 100
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Integrated
- Integrated
- Ethernet Controller
- Intel I217
- Data Link Protocol
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 4 (total) / 3 (free) x internal 3.5" x 1/3H
- Slots
- 1 (total) / 0 (free) x CPU , 4 DIMM 240-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCI - half-length, full-height
- 6 x USB 3.0 (2 front, 4 rear) , 1 x VGA , 2 x DisplayPort , 2 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x microphone
- Power-on password, serial port I/O control, USB port control, boot sequence control, Intel Active Management Technology (iAMT), boot without keyboard or mouse or diskette
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- FCC Class A certified, RoHS, GREENGUARD
- Power supply
- Voltage Required
- Power Provided
- 450 Watt
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- 17.5 cm
- 43.1 cm
- 37.5 cm
- 13 kg
- 10 °C
- 35 °C
- 10 - 80% (non-condensing)
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
