Lenovo TP X200 SERIES 6 CELL LI-ION BATTERY
Quicklinx: 79L8WS00 Mfr#: 43R9254
Device Type: Laptop
Type: Battery
Device Screen Size: [N/A]
£60.26 ex VAT
£72.31 inc VAT
The Lenovo ThinkPad battery 47+ allows you to increase the capacity of your 4-cell system battery on selected models or extend your unplugged computing time by carrying a spare. It is compatible with the X200 and X201 systems, and the design allows it to be in a system connected to the ThinkPad X200 UltraBase. The 6-cell, rechargeable battery utilises advanced Lithium Ion (Li-Ion) technology to create an efficient and balanced power source. The current is 10.8 volts and 5.2 ampere hours. The over-discharge protection safeguards against incorrect voltage and ensures a safe flow of power.
*Battery life varies due to many factors. These include: applications, battery conditioning, features, power management, screen brightness and other customer preferences. For more battery life information, go to lenovo.com/alldaycomputing.
Lenovo - laptop battery - Li-Ion - 5200 mAh
Laptop battery
330 g
Lithium Ion 6-cell - 5200 mAh
Batteries Qty
1
20.8 cm x 5.3 cm x 2 cm
1-year warranty
ThinkPad X200; X200s; X200si; X201; X201i; X201s
Laptop battery
Quantity
1
6-cell Lithium Ion
Voltage Provided
10.8 V
5200 mAh
UL, C-Tick, cUL, ACA
Limited warranty - replacement - 1 year
5 °C
35 °C
8 - 95%
20.8 cm
5.3 cm
2 cm
330 g
Lenovo ThinkPad X200 , Lenovo ThinkPad X200s , Lenovo ThinkPad X200si , Lenovo ThinkPad X201 , Lenovo ThinkPad X201i , Lenovo ThinkPad X201s
Lenovo TP X200 SERIES 6 CELL LI-ION BATTERY Bundle deal on Lenovo TP X200 SERIES 6 CELL LI-ION BATTERY
£153.29
Device Type: Laptop
Type: Battery
Brand: Lenovo
Price Range Ex VAT: 50 - 100
