Lenovo Tiny-in-one 23.8" 1920x1080 VGA DP LED Monitor
Quicklinx: CWBMWS00 Mfr#: 10LLPAT6UK
The ThinkCentre Tiny-in-One 24 is a light, slim monitor that comfortably manages your workspace. Equipped with LED panel, lift and tilt stand and DisplayPort connectivity, this monitor delivers reliable performance at an affordable price.
It also supports Tiny PC.
Lenovo ThinkCentre Tiny-in-One 24 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms
Colour Gamut
72%
Input Connectors
DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
Voltage
53.96 cm x 25.14 cm x 38.508 cm
5.57 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV, VESA DPMS, VESA FPMPMI, RoHS, ISO 9241-307, WEEE, DDC-2B/CI, UL Environmental SPC Gold, VOC
3-year warranty
Display Type
Diagonal Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.6
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Gamut
72%
Response Time
7 ms
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Anti-glare
Backlight Technology
WLED
53.96 cm x 25.14 cm x 38.508 cm - with stand
5.57 kg
Audio
Speakers - mono
Output Power / Channel
1.5 Watt
DisplayPort/USB 3.0/power (undetachable 3-in-1 cable) , Headphone/microphone combo jack , USB 3.0 upstream (Type B) , DisplayPort , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 88% efficiency power supply, detachable stand, Tiny PC dock
Mounting Kit
Optional
Input Voltage
Power Consumption (Typical)
16.7 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 53.96 cm - depth: 25.14 cm - height: 38.508 cm - weight: 5.57 kg , Without stand - width: 53.96 cm - depth: 6.82 cm - height: 34.645 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - replacement - 3 years - carry-in
8 - 80%
