Brand
Lenovo Tiny-in-One 22 21.5" 1920 x 1080 14ms Full HD LED monitor
Quicklinx: GF3GWS00 Mfr#: 11GSPAT1UK
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort
More than 50 in stock
£236.24 ex VAT
£283.48 inc VAT
Create an all-in-one PC using this 21.5" Full HD display, which is compatible with any ThinkCentre Tiny. The ThinkCentre Tiny simply inserts into the dedicated compartment behind the screen, enabling the PC to be upgraded independently of the display. Integrated web conferencing features include an adjustable webcam and speakers.
  • Modular convenience
    The ThinkCentre TIO22 Gen 4 makes it easy to create your own modular all in one (AIO). It instantly becomes a self-contained, fully functional AIO. But unlike other AIOs, the monitor and CPU refresh separately, making upgrades efficient and easy. The TIO is compatible with most ThinkCentre Tiny or Nano PCs, so you can have the right all in one for your business now.
  • Purposeful design
    This display is sleek and borderless and the unit takes up less space than previous generations. Its back cover has been redesigned for optimal heat dissipation and PC performance, and the stand includes a handy storage slot for your smartphone.
  • Connect and collaborate
    Thanks to the two 2W speakers and 720p rotatable camera and microphone, video calls are seamless and crystal-clear. The camera also features ThinkShutter, a privacy cover for when you're not videoconferencing. Additionally, the TIO22 Gen 4 monitor has plenty of ports, all conveniently situated for you to recharge and connect your other devices.
  • Ease and comfort of use
    The TIO22 Gen 4 has an antiglare filter to help make your viewing more comfortable. Its redesigned stand has an additional 40 mm of vertical lift, allowing for better ergonomics and more range in meeting your eye level. It also swivels 45 degrees in either direction, while the display tilts from -5 to 30 degrees and even rotates up to 90 degrees clockwise.
Lenovo ThinkCentre Tiny-in-One 22 Gen 4 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
USB 3.1 Gen 1 hub, 720p camera with dual microphone and Think Shutter
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms, 4 ms (overdrive), 14 ms (default)
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Dimensions (WxDxH) - with stand (lowest position)
48.93 cm x 22.04 cm x 41.82 cm
6.58 kg
EMEA
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
UL, VESA FPMPMI, RoHS, WEEE, GREENGUARD, Energy-Related Products (ErP) Lot 5, TUV Rheinland Eye Comfort Certification
3-year warranty
Display Type
Diagonal Size
21.5"
Built-in Devices
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Pixel Per Inch
102.4
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Gamut
72% NTSC (CIE 1931)
Response Time
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Anti-glare
Backlight Technology
WLED
3-sided bezeless
48.93 cm x 22.04 cm x 41.82 cm - with stand (lowest position)
6.58 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort/USB 3.1 gen 1/power (undetachable 3-in-1 cable) , USB 3.1 Gen 1 upstream , DisplayPort , USB 3.1 Gen 1 downstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
-5/+90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 88% efficiency power supply, Tiny PC dock
Mounting Kit
Optional
EMEA
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
14 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand (lowest position) - width: 48.93 cm - depth: 22.04 cm - height: 41.82 cm - weight: 6.58 kg , With stand (highest position) - width: 48.93 cm - depth: 22.04 cm - height: 56.82 cm - weight: 6.58 kg , Without stand - width: 48.93 cm - depth: 6.53 cm - height: 33.9 cm - weight: 3.41 kg
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
Response Time: 4ms
Brand: Lenovo
Stock Status: In stock
