Maximise desktop versatility and keep TCO in check. This compact Tiny-in-One (TIO) delivers a full All-in-One experience with simple setup, clutter-free cabling and extensive configurability options including a broad selection of Tiny products and accessories – all in a Tiny form factor. It's unique because it's an AIO, yet the CPU and monitor are separate modules so they can be maintained and upgraded individually – there's no need to replace or repair the entire system. Perfect for large organisations and any space-constrained environment.
Tiny modular All-in-One
Enjoy the improved compact design of this modular all-in-one desktop PC, with simple setup and enhanced security. Tiny-in-One is a 23-inch monitor with built-in housing for both a Tiny system and an external optical disc drive, which are secured via one single Kensington lock, and remain secure inside the system even if the cable is cut. -
Reduced upkeep costs
With the Tiny-in-One 23, you need only update what you need, when you need to - no worries about replacing the entire system as with traditional all-in-one desktops. -
Easily connects to a laptop
The Tiny-in-One easily connects to a laptop, and with the press of a button, you can switch sources between notebook and Tiny. Tiny-in-One also functions as a standalone monitor. -
Big on security
A single Kensington lock secures Tiny and extension ODD box together for enhanced security. Tiny-in-One is compatible with other data security features offered by Tiny, such as Smart USB Protection and Bluetooth lock.
- Lenovo ThinkCentre Tiny-in-One 23 - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DisplayPort
- Height, swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.3 cm x 25 cm x 52.014 cm
- 7 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, CSA, TUV, TUV GS, VCCI, C-Tick, BSMI, cUL, VESA DPMS, VESA FPMPMI, CCC, IC, RoHS, ISO 9241-307, WEEE, JEITA, KC, CECP, DDC-2B/CI
- 3-year warranty
- Display Type
- Diagonal Size
- 23"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Pixel Per Inch
- 96
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Black
- 56.3 cm x 25 cm x 52.014 cm - with stand
- 7 kg
- DisplayPort , Headphone/microphone combo jack
Mechanical
- Tilt Angle
- 35
- Swivel Angle
- 45
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), 88% efficiency power supply
- Mounting Kit
- Optional
- Localisation
- Power Supply
- External
- Input Voltage
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1
Sustainability Information
- ENERGY STAR Certified
- International warranty - replacement - 3 years
- 0 °C
- 40 °C
- 8 - 80%
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
