Lenovo ThinkVision T27q-20 - LED monitor - 27" (27" viewable) - 2560 x 1440 QHD - IPS - 350 cd/m² - 1000:1 - 4 ms - HDMI, DisplayPort - raven black
Uncompromised
Experience exceptional image quality on the QHD (2560 x 1440), In-Plane Switching display that offers a wide viewing angle. Run applications while checking on multiple spreadsheets-deploy two or more of these 3-sided NearEdgeless monitors side-by-side, for an uninterrupted view and effortless multitasking. Convenient and perfect for any workspace, this monitor helps enhance efficiency. -
Efficient and Smart Working
Maximize your productivity with multiple ports by connecting to all essential peripherals effortlessly. The monitor has dedicated DisplayPort, four USB 3.1 Gen1 ports, and an HDMI port for seamless connectivity during meetings and presentations. Connect the monitor to an optional speaker via audio out port for a complete audio visual experience. -
Ergonomic and Space-saving Solution
Place your monitor either on its sturdy stand or mount it up on the wall, using VESA mount for comfortable viewing. The extended tilt and lift range is ergonomic, allowing you to spend time in front of the monitor without fatigue. The cable management, smaller base, and integrated phone holder further add to your convenience and help you work efficiently, by keeping your desk space organized.
- Lenovo ThinkVision T27q-20 - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class E
- Power Consumption (On mode)
- 21.2 W
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms (extreme), 14 ms (Off), 6 ms (typical)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 20.8 cm x 61.4 cm x 42.94 cm
- 7.44 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
- CCC, RoHS, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 60 Hz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Integrated cable management, 3-side NearEdgeless, 99% sRGB colour gamut
- Raven black
- 20.8 cm x 61.4 cm x 42.94 cm - with stand
- 7.44 kg
- DisplayPort , HDMI , Headphones , USB 3.1 Gen 1 downstream with Battery Charging , 3 x USB 3.1 Gen 1 downstream , USB 3.1 Gen 1 upstream (Type B)
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 135 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB-B to USB-A cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 21.2 W
- Power Consumption SDR (On mode)
- 21.2 kWh/1000h
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand (lowest position) - width: 20.8 cm - depth: 61.4 cm - height: 42.94 cm - weight: 7.44 kg , With stand (highest position) - width: 20.8 cm - depth: 61.4 cm - height: 56.44 cm - weight: 7.44 kg , Without stand - width: 4.67 cm - depth: 61.4 cm - height: 36.91 cm - weight: 4.93 kg
- Shipping Width
- 48 cm
- Shipping Depth
- 69.4 cm
- Shipping Height
- 16.3 cm
- Shipping Weight
- 9.59 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Limited warranty - 3 years
Lenovo Thinkvision MC50 Monitor Webcam | In Stock | £54.13 |
