The ThinkVision T27p is designed to provide you with a spectacular viewing experience. The NearEdgeless screen and 3840 x 2160 resolution make it an excellent productivity tool. The USB Type-C port provides a perfect one-cable solution by transiting data, video, and providing power delivery to compatible devices. Multiple USB ports enable easy connectivity to peripherals, making it a truly great investment for professionals in any industry who rely on additional monitors to multitask. Moreover, the ergonomically designed stand with lift, tilt, pivot, and swivel functionalities allows you to adjust the monitor for your comfort.
- Lenovo ThinkVision T27p-10 - LED monitor - 4K - 27"
- LED-backlit LCD monitor - 27"
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160
- Pixel Pitch
- 0.1554 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 14 ms (grey-to-grey); 6 ms; 4 ms (extreme)
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- 61.16 cm x 21 cm x 40.33 cm
- 6.95 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- CCC, RoHS, UL Environmental SPC Gold, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification
- 3-year warranty
- Display Type
- Diagonal Size
- 27"
- Viewable Size
- 27"
- Built-in Devices
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160
- Pixel Pitch
- 0.1554 mm
- Pixel Per Inch
- 163
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Bezel Type
- Flat front
- 99% colour gamut
- 61.16 cm x 21 cm x 40.33 cm - with stand
- 6.95 kg
- HDMI , DisplayPort , USB-C , USB 3.1 Gen 1 downstream with Battery Charging , 4 x USB 3.1 Gen 1 downstream , Headphones
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB-C cable - 1.8 m , 1 x HDMI cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 50 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 61.16 cm - depth: 21 cm - height: 40.33 cm - weight: 6.95 kg , Without stand - width: 61.16 cm - depth: 4.5 cm - height: 36.84 cm - weight: 5 kg
- Shipping Width
- 45.3 cm
- Shipping Depth
- 73.2 cm
- Shipping Height
- 21 cm
- Shipping Weight
- 11 kg
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.1
- Limited warranty - 3 years
