Brand
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: FGN0WS00 Mfr#: 61DAMAT1UK
Diagonal Size: 27in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: None
Interfaces: DisplayPort, USB-C, HDMI
£469.18 ex VAT
£563.01 inc VAT
The ThinkVision T27p is designed to provide you with a spectacular viewing experience. The NearEdgeless screen and 3840 x 2160 resolution make it an excellent productivity tool. The USB Type-C port provides a perfect one-cable solution by transiting data, video, and providing power delivery to compatible devices. Multiple USB ports enable easy connectivity to peripherals, making it a truly great investment for professionals in any industry who rely on additional monitors to multitask. Moreover, the ergonomically designed stand with lift, tilt, pivot, and swivel functionalities allows you to adjust the monitor for your comfort.
Lenovo ThinkVision T27p-10 - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class G
Power Consumption (On mode)
29.7 W
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
6 ms, 14 ms (grey-to-grey), 4 ms (extreme)
Colour Support
1.07 billion colours
Colour Gamut
99%
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
61.16 cm x 21 cm x 40.33 cm
6.95 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
CCC, RoHS, UL Environmental SPC Gold, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification
3-year warranty
Display Type
Energy Class
Class G
Diagonal Size
27"
Built-in Devices
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.1554 mm
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99%
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
61.16 cm x 21 cm x 40.33 cm - with stand
6.95 kg
HDMI , DisplayPort , USB-C , USB 3.1 Gen 1 downstream with Battery Charging , 4 x USB 3.1 Gen 1 downstream , Headphones
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
180
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x USB-C cable - 1.8 m , 1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
29.7 W
29.7 kWh/1000h
Power Consumption (Typical)
50 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.16 cm - depth: 21 cm - height: 40.33 cm - weight: 6.95 kg , Without stand - width: 61.16 cm - depth: 4.5 cm - height: 36.84 cm - weight: 5 kg
Shipping Width
45.3 cm
Shipping Depth
73.2 cm
Shipping Height
21 cm
Shipping Weight
11 kg
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.1
Limited warranty - 3 years
Diagonal Size: 27in
Response Time: 4ms
Speakers: None
Interfaces: USB-C
Interfaces: HDMI
Brand: Lenovo
Stock Status: In stock
