Brand
Lenovo ThinkVision T27h-20 27" 2560x1440 4ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: FPV5WS00 Mfr#: 61ECGAT2UK
Boost productivity at work with the ThinkVision T27h-20 monitor that allows you to complete data-intensive work and content editing efficiently. The 27-inch In-Plane Switching panel displays accurate and clear details from all angles, while its QHD resolution - with 1.77 times more pixels than a Full-HD display - enhances visual clarity for business professionals. Its 3-side NearEdgeless screen makes it easy to create a multi-screen setup for seamless multitasking. Maximize your desk space with the USB Type-C one-cable solution that comes integrated with Smart Power for better connectivity and power efficiency.
  • High-performance display solution
    The 2560 x 1440 resolution and 27-inch display mean more pixels that offer greater details and make working on large spreadsheets and designs a breeze. Professionals can set up a multi-screen workspace, with 3-side NearEdgeless bezels on the T27h monitor for effortless multitasking. Thanks to the 99% sRGB color gamut, you can get crisp and vibrant images with realistic colors, perfect for content creation.
  • Smart connectivity
    The USB Type-C one-cable solution, HDMI port, dedicated DisplayPort, and USB hub ensure you have uninterrupted connectivity during meetings or presentations. You can now enjoy a seamless multi-screen experience, thanks to the flexibility of using various peripherals. Additionally, the Smart Power function intelligently detects overall power consumption and dynamically manages the power delivery to each device. Get up to 75W of power delivery through the USB Type-C cable with the Smart Power function.
  • Ergonomic and user-friendly design
    This monitor is a smart choice for all businesses. The increased lift range and tilt angle, along with swivel and pivot functionality, let you adjust the screen for easy collaboration and comfortable viewing. An integrated phone holder, VESA mount, minimized square base, and flexible cable management ensure you have a clutter-free desk space.
Lenovo ThinkVision T27h-20 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Power Consumption (On mode)
22 W
USB 3.1 Gen 1 hub, USB PD 75 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
14 ms (Off); 6 ms (typical); 4 ms (extreme)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Raven black
20.8 cm x 61.4 cm x 42.94 cm
7.6 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
CCC, RoHS, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.1 Gen 1 hub
USB Power Delivery
75 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
60 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
99% sRGB colour gamut, integrated cable management, 3-side NearEdgeless
Raven black
20.8 cm x 61.4 cm x 42.94 cm - with stand
7.6 kg
DisplayPort , HDMI , Headphones , USB 3.1 Gen 1 downstream with Battery Charging , 3 x USB 3.1 Gen 1 downstream , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode with Power Delivery (power up to 75W)
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Rotation Angle
180
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x USB-C cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
22 W
22 kWh/1000h
Power Consumption (Typical)
23 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand (highest position) - width: 20.8 cm - depth: 61.4 cm - height: 56.44 cm - weight: 7.6 kg , With stand (lowest position) - width: 20.8 cm - depth: 61.4 cm - height: 42.94 cm - weight: 7.6 kg , Without stand - width: 4.67 cm - depth: 61.4 cm - height: 36.91 cm - weight: 5.09 kg
Shipping Width
48 cm
Shipping Depth
69.4 cm
Shipping Height
16.3 cm
Shipping Weight
9.75 kg
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
