Lenovo ThinkVision T25m-10 25" 1920x1200 HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: FGMGWS00 Mfr#: 61DCRAT1UK
Diagonal Size: 25in
Max Resolution: 1920 x 1200
Response Time: 4ms
Speakers: None
Interfaces: DisplayPort, USB-C, HDMI
£279.18 ex VAT
£335.01 inc VAT
The ThinkVision T25m 25-inch monitor with a 16:10 aspect ratio, offers 8% larger display area than a traditional 24-inch 16:10 monitor, perfect for commercial users who need additional screen real estate. Engineered to produce lifelike visuals, the WUXGA 1920 x 1200 resolution display offers remarkable clarity. Modern connectivity options on the T25m enable easy collaboration along with performance. The USB Type-C cable and integrated speakers combo offers an impressive audio-visual experience. The ergonomic built provides optimum user comfort. With a NearEdgeless screen and smart, productivity-boosting features, the ThinkVision T25m is the next-generation display.
  • Stunning visual experience
    Enjoy stunning views from all angles with the In-Plane Switching display and wide viewing angle. With up to 4ms response time, the WUXGA 16:10 display minimizes motion-blur and eliminates streaking for a seamless viewing experience. The 99% sRGB color space on the monitor makes color consistency a standard for any usage.
  • Advanced connectivity
    Connect and collaborate easily with ports such as USB Type-C, four USB 3.1 Gen1, HDMI, and DP. The modern USB Type-C port provides audio, data, and video delivery all via a single cable. It also supports the Smart Power function that intelligently detects overall power consumption and dynamically manages the delivery. Plus, the internal speakers offer an immersive audio experience.
  • Clarity with comfort
    Minimize eye fatigue with the TÜV Eye Comfort certified anti-glare display that protects the eyes from blue light emission. Find your ideal working position with the lift, tilt, pivot, and swivel functionalities. The tool-free design makes it easy to assemble. Also, the cable management hoop helps keep your desk organized and clutter-free.
Lenovo ThinkVision T25m-10 - LED monitor - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class F
Power Consumption (On mode)
22.5 W
USB 3.1 Gen 1/USB-C hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.2823 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
6 ms (typical); 4 ms (extreme)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100 - 240 V (50 - 60 Hz)
54.87 cm x 26.04 cm x 50.95 cm
5.5 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
CCC, UL Environmental SPC Gold, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification, EU RoHS, ULE Gold
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
25"
Viewable Size
25"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.2823 mm
Pixel Per Inch
91
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
99% sRGB colour gamut
54.87 cm x 26.04 cm x 50.95 cm - with stand
5.5 kg
HDMI , DisplayPort , USB-C upstream , 4 x USB 3.1 Gen 1 , Audio line-out
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x USB cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
22.5 W
22.5 kWh/1000h
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows 7, Windows 10
Dimensions & Weight Details
With stand - width: 54.87 cm - depth: 26.04 cm - height: 50.95 cm - weight: 5.5 kg , Without stand - width: 54.87 cm - depth: 4.3 cm - height: 36.91 cm - weight: 3.58 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 25in
Response Time: 4ms
Speakers: None
Interfaces: USB-C
Interfaces: HDMI
Brand: Lenovo
