The ThinkVision T25m 25-inch monitor with a 16:10 aspect ratio, offers 8% larger display area than a traditional 24-inch 16:10 monitor, perfect for commercial users who need additional screen real estate. Engineered to produce lifelike visuals, the WUXGA 1920 x 1200 resolution display offers remarkable clarity. Modern connectivity options on the T25m enable easy collaboration along with performance. The USB Type-C cable and integrated speakers combo offers an impressive audio-visual experience. The ergonomic built provides optimum user comfort. With a NearEdgeless screen and smart, productivity-boosting features, the ThinkVision T25m is the next-generation display.
Stunning visual experience
Enjoy stunning views from all angles with the In-Plane Switching display and wide viewing angle. With up to 4ms response time, the WUXGA 16:10 display minimizes motion-blur and eliminates streaking for a seamless viewing experience. The 99% sRGB color space on the monitor makes color consistency a standard for any usage. -
Advanced connectivity
Connect and collaborate easily with ports such as USB Type-C, four USB 3.1 Gen1, HDMI, and DP. The modern USB Type-C port provides audio, data, and video delivery all via a single cable. It also supports the Smart Power function that intelligently detects overall power consumption and dynamically manages the delivery. Plus, the internal speakers offer an immersive audio experience. -
Clarity with comfort
Minimize eye fatigue with the TÜV Eye Comfort certified anti-glare display that protects the eyes from blue light emission. Find your ideal working position with the lift, tilt, pivot, and swivel functionalities. The tool-free design makes it easy to assemble. Also, the cable management hoop helps keep your desk organized and clutter-free.
- Lenovo ThinkVision T25m-10 - LED monitor - 25"
- LED-backlit LCD monitor - 25"
- Energy Class
- Class F
- Power Consumption (On mode)
- 22.5 W
- USB 3.1 Gen 1/USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.2823 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms (extreme), 6 ms (typical)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100 - 240 V (50 - 60 Hz)
- Black
- 54.87 cm x 26.04 cm x 50.95 cm
- 5.5 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- CCC, UL Environmental SPC Gold, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification, EU RoHS, ULE Gold
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 25"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.2823 mm
- Pixel Per Inch
- 91
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- 99% sRGB colour gamut
- Black
- 54.87 cm x 26.04 cm x 50.95 cm - with stand
- 5.5 kg
- HDMI , DisplayPort , USB-C upstream , 4 x USB 3.1 Gen 1 , Audio line-out
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 22.5 W
- Power Consumption SDR (On mode)
- 22.5 kWh/1000h
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- OS Required
- Microsoft Windows 7, Windows 10
- Dimensions & Weight Details
- With stand - width: 54.87 cm - depth: 26.04 cm - height: 50.95 cm - weight: 5.5 kg , Without stand - width: 54.87 cm - depth: 4.3 cm - height: 36.91 cm - weight: 3.58 kg
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 3 years
