Brand
Lenovo ThinkVision T25d-10 25" 1920x1200 VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FGMFWS00 Mfr#: 61DBMAT1UK
Diagonal Size: 25in
Max Resolution: 1920 x 1200
Response Time: 4ms
Speakers: None
Interfaces: VGA (HD-15), HDMI, DisplayPort
More than 50 in stock
£244.18 ex VAT
£293.01 inc VAT
The ThinkVision T25d with its 25-inch NearEgdeless In-Plane Switching screen redefines visual clarity. The 16:10 aspect ratio with 11% more pixels than full-HD offer more screen real estate for seamless multitasking. Versatile HDMI, DisplayPort, and legacy VGA ports enable easy connectivity to your favorite work essentials. Impressive 4ms response time minimizes motion blur, allowing you to enjoy smooth, flicker-free visuals from any angle. Well suited for number crunching, or graphic designing, the ThinkVision T25d monitor is a smart investment for professionals whose job role requires them to be more detail-oriented
  • Superior viewing experience
    Enjoy 11% more pixel than a Full HD screen and 8% more visual space than a 24-inch 16:10 monitor. The ThinkVision T25d is primed to captivate you with its edge-to-edge visual experience. View accurate colors with the 99% sRGB color gamut that offers unparalleled color range for quality content creation.
  • Quick connectivity
    Take a break from switching between tabs as the T25d monitor comes equipped with legendary VGA, modern HDMI and DP Ports that allow connectivity to additional monitors. The four USB 3.1 Gen 1 ports meet various connectivity needs, enabling you to check off your to-do list faster. Also, the 'USB always-on' mode allows you to charge your devices through the monitor.
  • Easily adjustable and ergonomic
    The full-function monitor stand lets you lift, tilt, pivot, or swivel the device, allowing you to work comfortably. You can also install a ThinkCentre Tiny PC easily with the VESA compatible mount to experience fast and powerful computing in a sleek, space-saving design.
Lenovo ThinkVision T25d-10 - LED monitor - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class D
Power Consumption (On mode)
15.8 W
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.2823 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 6 ms (typical)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 100 - 240 V (50 - 60 Hz)
54.87 cm x 26.04 cm x 39.95 cm
5.5 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
CCC, UL Environmental SPC Gold, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification, EU RoHS, ULE Gold
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
25"
Built-in Devices
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.2823 mm
Pixel Per Inch
91
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Anti-glare, 99% sRGB colour gamut
54.87 cm x 26.04 cm x 39.95 cm - with stand
5.5 kg
VGA (HD-15) , HDMI , DisplayPort , 4 x USB 3.1 Gen 1 , USB 3.1 Gen 1 , Audio line-out
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
15.8 W
15.8 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows 7, Windows 10
Dimensions & Weight Details
With stand - width: 54.87 cm - depth: 26.04 cm - height: 39.95 cm - weight: 5.5 kg , Without stand - width: 54.87 cm - depth: 4.3 cm - height: 36.91 cm - weight: 3.58 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 25in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Lenovo
Stock Status: In stock
