Brand
Lenovo ThinkVision T24m 23.8" 1920x1080 6ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: FGM6WS00 Mfr#: 61CFRAT2UK
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: None
Interfaces: HDMI, DisplayPort, USB-C
£195.29 ex VAT
£234.34 inc VAT
There's no need to compromise performance and functionality for cost. The affordable Lenovo ThinkVision T24m has it all - 23.8" of Full HD near-edgeless display for outstanding images and crisp text from center to sides, along with convenient one-cable solution USB Type C and broad connectivity. It is ideal for enterprise and home, office, also features full-function, ergonomic stand and TüV certification to optimize your use experience.
  • Truly superior display
    The brilliant 23.8" Full HD (1920 x 1080) wide-view display features In-Plane switching for clear, vivid imagery, and response time as low as 4 ms to minimize motion blur.
  • Convenient one-cable connection
    A single USB Type C cable delivers video (DisplayPort 1.2), data (USB 3.0) and power to a notebook, tablet or smartphone, along with versatile digital ports make device connectivity easy.
  • Ergonomic design
    Suits any environment with full-function adjustable stand. TüV certification means reduced blue light to reduce eye fatigue during all-day viewing.
Lenovo ThinkVision T24m-10 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Power Consumption (On mode)
15 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
6 ms
Colour Gamut
99% sRGB
Input Connectors
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
54.02 cm x 26.175 cm x 37.34 cm
5.6 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
FCC Class B certified, RoHS, ISO 9241-307, WEEE, DDC-2B/CI, UL Environmental SPC Gold, DisplayPort 1.2, China Energy standard Tier 2
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
99% sRGB
Response Time
6 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+89 / -89
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
English, German, French, Italian, Russian, Spanish, Japanese, Chinese
HDCP, Mercury free, arsenic free, 99% sRGB colour gamut
54.02 cm x 26.175 cm x 37.34 cm - with stand
5.6 kg
HDMI (HDCP) , DisplayPort (HDCP) , USB-C , Audio line-out , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, detachable stand
1 x USB-C cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
15 W
15 kWh/1000h
Power Consumption (Typical)
17 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 54.02 cm - depth: 26.175 cm - height: 37.34 cm - weight: 5.6 kg , Without stand - width: 54.02 cm - depth: 4.645 cm - height: 32.598 cm - weight: 3.73 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
10 - 80%
Response Time: 6ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: Lenovo
