Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FGM5WS00 Mfr#: 61B4MAT1UK
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 7ms
Speakers: None
Interfaces: VGA (HD-15), HDMI, DisplayPort
23 in stock
£231.52 ex VAT
£277.82 inc VAT
The sleek, stylish Lenovo ThinkVision T24d-10 monitor doesn't just display images - it presents them in exceptionally crisp resolutions. Enjoy vivid images across wide viewing angles with no color distortion or reflection. With elegant slim design, the monitor fits in any workspace.
  • Professional performance
    Professional performance defines this monitor, featuring exceptional viewing angles.
  • Great productivity
    A full-function stand ensures your display sports an executive look regardless of whether you swivel, tilt, pivot, or lift. Paired with near-edgeless screen, you can enjoy a clean look and seamless views.
Lenovo ThinkVision T24d-10 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Power Consumption (On mode)
15.2 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
53.32 cm x 26.04 cm x 49.74 cm
5.63 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
FCC Class B certified, RoHS, ISO 9241-307, WEEE, VESA DDC 2 B
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200
Pixel Pitch
0.27 mm
Pixel Per Inch
94
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP, 99% colour gamut
5.63 kg
VGA (HD-15) , HDMI (HDCP) , DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x USB cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
15.2 W
15.2 kWh/1000h
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Microsoft Windows 7, Windows 10
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 24in
Response Time: 7ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Lenovo
Stock Status: In stock
