The ThinkVision T2424p LCD Monitor offers FHD resolution and a professional In-plane Switching panel to maximise the viewing angle and visual experience. It offers multiple interface options (VGA + HDMI + DP) and integrated USB3.0 hub, making it easy to connect. Boasting low energy consumption and less environmental impact, it meets the latest green standards: Energy Star 6.0, TUV Green Mark, EPEAT Gold, UL Environment Gold and more.
- Lenovo ThinkVision T2424p - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 7 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA, DisplayPort
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 56.36 cm x 26.42 cm x 37.25 cm
- 5.85 kg
- Localisation
- English / United Kingdom
- FCC Class B certified, MPR II, CSA, UL, TUV GS, VCCI, C-Tick, BSMI, cUL, GS, NEMKO, NOM, SABS, SASO, TUV S, CCC, IC, PSB, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, JEITA, MEPS, E-Standby, TUV GM, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, CEL, UL Environmental SPC Gold, INSM, EAC, ISC
- 3-year warranty
- Display Type
- Diagonal Size
- 23.8"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 7 ms
- Vertical Refresh Rate
- 60 - 75 Hz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, input select, colour temperature
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
- Anti-glare
- Raven black
- 5.85 kg
- VGA , HDMI , DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management
- Cables Included
- 1 x SuperSpeed USB cable - 1.8 m , 1 x VGA cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- Microsoft Windows Vista / 7 / 8 / 8.1
- Dimensions & Weight Details
- Without stand - width: 56.36 cm - depth: 4.4 cm - height: 33.3 cm - weight: 3.85 kg
- Limited warranty - 3 years - carry-in
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
