Lenovo ThinkVision T23d 22.5" 1920x1200 VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FGMBWS00 Mfr#: 61C3MAT6UK
Diagonal Size: 22.5in
Max Resolution: 1920 x 1200
Response Time: 6ms
Speakers: None
Interfaces: VGA (HD-15), DisplayPort, HDMI
£233.56 ex VAT
£280.27 inc VAT
The Lenovo ThinkVision T23d-10 is a superior monitor that is meant to take your efficiency to new heights. With the vivid 22.5-inch display and versatile connectivity options, the ThinkVision T23d-10 lets you perform with your full potential.
The 16:10 aspect ratio of the T23d-10 monitor makes for an extra wide display and a superior viewing experience. The borderless panel of the bright WUXGA monitor and the super narrow bezel make it ideal for multi-screen connection, adding to your productivity. With up to 4ms response time, the anti-glare display minimizes motion blur and eliminates streaking and ghosting for a smooth interaction. The ThinkVision T23d-10 has a range of ports such as VGA, DP, and HDMI to boost productivity.
  • Increase Your Efficiency
    The 22.5-inch borderless display offers 11% more space, allowing you to do much more. The extra thin bezel is beneficial especially if you are dealing with extensive data and need to work with multiple screens.
  • Adaptable and Ergonomic
    The ThinkVision T23d-10 is built to support you in any work environment. The wide 178° viewing angle eliminates disturbing reflections and makes for a brilliant and bright display, so you don't miss a single detail. Easy to assemble (tool-free), the ergonomic stand can lift, tilt, pivot, and swivel at your will. For a clutter-free desk, manage cables with the clip behind the stand.
  • Clarity with Comfort
    Promoting eye-safety, the ThinkVision T23d-10 comes with the TÜV Eye Comfort certification. It is the solution to long hours at the desk. Also, these monitors emit low blue light, which lessens eye-strain without hindering your productivity
Lenovo ThinkVision T23d-10 - LED monitor - 22.5"
LED-backlit LCD monitor - 22.5"
Energy Class
Class D
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200
Pixel Pitch
0.25 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms
Colour Gamut
72%
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
50.12 cm x 25.19 cm x 49.19 cm
4.85 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
FCC Class B certified, RoHS, ISO 9241-307, WEEE, DDC-2B/CI
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
22.5"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200
Pixel Pitch
0.25 mm
Pixel Per Inch
100.6
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Gamut
72%
Response Time
6 ms
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
WLED
HDCP
4.85 kg
VGA , HDMI (HDCP) , DisplayPort (HDCP)
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , Power cable
Security Slot Type
Kensington security slot
Input Voltage
13.9 kWh/1000h
Power Consumption (Typical)
15 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Microsoft Windows 7 / 10
Dimensions & Weight Details
Width: 50.12 cm - depth: 25.19 cm - height: 49.19 cm - weight: 4.85 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
Response Time: 6ms
Speakers: None
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Lenovo
